80/20 FTTC trial
- Full Fibre
- Re: 80/20 FTTC trial
19-01-2012 11:04 AM
The install was 12/1, so I suppose it depends on what profile they stuck it on at the time. I'd assume that as it is recent, it's most likely to be on the 17a, so should see a bump as it was hitting the 40/2 limits on sync.
19-01-2012 2:43 PM
20-01-2012 2:21 PM
Downstream Speed 59.5 Mbps
Upstream Speed 20.0 Mbps
So you should see a bit more speed hopefully. A couple of people didn't see the full speed immediately though and had to switch the BT modem and router off for a minute. BTW saw an issue where the profile on their side wasn't updating and the easiest way of forcing a reset was to just power off for a minute. Worth a try to see if that makes any difference.
ashgeo - thanks for all the test results that's really useful. We saw some inconsistencies in the speed tests at these kinds of speeds on FTTP too, it gets much harder to measure as accurately the faster the speeds get it seems.
Plusnet Technology
20-01-2012 4:02 PM
Quote from: dave unbound, the sync speed of your line is currently showing as:
Thanks for the numbers Dave.
I tried running the BT speedtester this morning, and just got a busy notification (rather amusing at 730 in the morning), but I did do a real download test and it seemed to be giving that sort of rate (actually giving a higher rate, I was getting reported download of 6.6MBs sustained for 10mins), so that's looking good. That was wired though, so I think wifi is bottlenecking a bit.
Upstream is a case of needing to rebuild my aging XP box first into something that will sensibly supply some data - It's a good excuse to change it into the linux server I've been meaning to covert it to
I'll try a restart of the modem as well and see what it thinks as well - Ta.
21-01-2012 5:54 PM
Steve
22-01-2012 11:58 AM
24-01-2012 5:59 PM
I've done several tests over the past couple of days and it won't register above around 38meg down. I Know that I can currently get just under 65meg down (am on the 80/20 trail)...
Speedtest.net consistently reports in the range 64-65meg.
George
24-01-2012 10:01 PM
25-01-2012 11:16 AM
Jojo
25-01-2012 11:28 AM
It should work fine on the BT speedtester, does it do that every time?
Jojo
26-01-2012 7:04 PM
27-01-2012 12:28 AM
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
27-01-2012 10:52 AM
27-01-2012 3:50 PM
01-02-2012 10:31 AM
