80/20 FTTC trial
- Full Fibre
- 80/20 FTTC trial
- « Previous
- Next »
Re: 80/20 FTTC trial
17-02-2012 10:49 AM
i'd be up for the trial, but would like to know what the cost is likely to be first
and what the other product details will be, eg usage amount which i suspect will become a big issue...
Message 76 of 83
(633 Views)
17-02-2012 7:03 PM
I'm not sure where, but it was hinted that during the next phase more/all exhcanges will be able to take part and you would have to be on one of the fibre packages. I dont mind upgrading to a current package if it means I can take part, its more than fair
If its more costly I'd still be interested
Message 77 of 83
(633 Views)
17-02-2012 9:30 PM
Quote from: mikeyriot If its more costly I'd still be interested
been unemployed for over a year now and things are pretty tight so have to be careful...
Message 78 of 83
(633 Views)
17-02-2012 10:02 PM
Quote from: bluewhale usage amount which i suspect will become a big issue...
If my calculator is correct then, in theory, you could use a month's 'Extra' allowance (120GB) in under 4 hours if you managed to continuously use 80Mbps!
[Edit] Corrected 80Gbps to 80Mbps, thanks KevinG
Call me 'w23'
Message 79 of 83
(633 Views)
18-02-2012 8:52 AM
Yes, that's about right, allowing for overheads, but it's 80Mbps, not 80Gbps, at that speed you'd use it in 12 seconds!
Message 80 of 83
(633 Views)
20-02-2012 1:23 PM
still no news?
Message 81 of 83
(633 Views)
21-02-2012 3:47 PM
There is now, look at top of 'Fibre Trials' board (in case you missed it).
Call me 'w23'
Message 82 of 83
(633 Views)
21-02-2012 9:17 PM
mod:note
locked as there is now a sign up thread.
Message 83 of 83
(633 Views)
- « Previous
- Next »
