smart tv
mariayged
smart tv
We have a polaroid smart TV but we cannot connect it.
It detects the router, asks for the password, then displays 'Please wait' for about ten seconds and that's it, nothing.
Does anyone know where are we going wrong?
9 REPLIES 9
AndyH
Re: smart tv
Are you using the Plusnet supplied TG582N router?
HairyMcbiker
All Star
Fixes: 21
Re: smart tv
Make sure you are entering the wifi password, and that you have CapitaliZation right and 0's and not o's.
mariayged
Re: smart tv
Yes we are. We have a new plusnet mdoem and router.
mariayged
Re: smart tv
We have entered the password correctly, numerous times now
AndyH
Re: smart tv
Can you try changing the wireless channel on the router from automatic to 6 to see if that helps?
Fixes: 397
Re: smart tv
If nothing else works then you could try setting a static IP on the TV as described in this thread http://community.plus.net/forum/index.php/topic,122172.msg1059521.html#msg1059521
mariayged
Re: smart tv
Thanks Andy H and Mister W!
I would like to try first changing the wireless channel, but, sorry!! could you explain to me how to do it?
Failing that I'll try setting a static IP (Just had a quick look at the tread...sounds complicated but I'll give it a go!
AndyH
Re: smart tv
mariayged
Re: smart tv
We can now connect to the internet by changing the security mode from OPEN to WPA-PSK Cheesy
But we can't save the settings, so every time we select internet on the TV we need to go through all the steps.
Does anybody know how can we save the settings?
