orange light
- orange light
orange light
06-04-2018 6:39 PM
I have a hub one which I can connect to the Internet with by using iPad and phone but my laptop does not unless I use the Ethernet cable, I can not find any mention of this steady orange light please can someone help
Message 1 of 2
(2,873 Views)
1 REPLY 1
Re: orange light
06-04-2018 7:05 PM
Welcome to the community forums @dandrfuller
It sounds like WiFi might be switched off in the router settings.
Can you try a factory reset by pushing a paperclip into the reset hole at the back for 20 seconds?
Let us know how you get on.
Message 2 of 2
(2,860 Views)
