is this Unlimited Fibre or Unlimited Fibre Extra?
FIXED- Subscribe to RSS Feed
- is this Unlimited Fibre or Unlimited Fibre Extra?
Re: is this Unlimited Fibre or Unlimited Fibre Extra?
11-07-2020 8:44 AM
Thanks for getting in touch @SteveA
I'm sorry for the issues with renewing and your speed.
I can confirm you're provisioned on 80/20. Your package is a legacy one named Plusnet Unlimited Fibre which is the same in every way as the modern day Unlimited Fibre Extra. Unfortunately it looks like the particular system that provides a renewal offer online is confusing the legacy fibre extra package with the current Unlimited Fibre (40/10) package.
If you want to renew your contract on fibre extra I'd recommend calling our customer options team on 0800 013 2632. They may be able to move you to the current fibre extra naming in the process to avoid this issue in future.
With regards to your speed, together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
As a side note,
@Browni wrote:Going back a few years there was a package called 'Unlimited Fibre' that had 80/20 speeds.
Plusnet's naming convention can lead to some confusion
I believe you're referring to our legacy 40/20 package that was 80/20 capped down by us, which we then withdrew in favour of 40/2 but moved existing 40/20 users on to 55/10 as a goodwill gesture.
11-07-2020 9:21 AM
No, I was referring to legacy 'Plusnet Unlimited Fibre' but missed the 'Plusnet' prefix.
I rest my case about confusing naming standards 🤣
11-07-2020 10:48 AM
Although you would have to change providers you at least have the option of WBC FTTP.
Try your number here to see if there are any plans for your area
11-07-2020 11:11 AM - edited 11-07-2020 11:12 AM
@bmc - only a vague future promise of FTTP,:
Full Fibre (Fibre to the Premises - FTTP)
Technology that supports speeds up to 1Gbps
Faster and more reliable fibre is coming to your area soon. Full Fibre is our fastest technology, but your exact speed will depend on which broadband provider and package you choose. Sign up for news and updates.
It's been "soon" for as long as they've been talking about it.
11-07-2020 1:27 PM
@SteveA On my block we already have Full Fibre (Fibre to the Premises - FTTP) Technology that supports speeds up to 1Gbps, although it's only 200mbps up! But I'm hopeful PlusNet can sort out my stuff, so I don't have to leave all you nice people to get some speed. (speed OMG I'm beginning to sound like a Junkie) 🤣
11-07-2020 2:14 PM
@Leapy - there is FTTP in the new development about 300 metres from me, but we're still on long dangling overhead wires and rotting wooden poles (and crazy wiring where the cab I'm connected to is a long way away and I have to walk past other cabs (with their FTTC partner cabs) before I get to mine). BT have made it quite clear in the past that they have no intention of improving our connectivity - not even Fibre to the Pole, and as I said FTTP has been "coming soon" since day 1.
11-07-2020 4:04 PM
OpenReach won't waste money sorting the old wired connections if they're planning FTTP. From your posting they are indeed "planning" FTTP so they do "plan" to improve your connectivity - it's just a question of when.
If there's a problem with the poles I suspect these would need to be replaced as part of (or before) a FTTP deployment as the Distribution Point (DP) is hung from the pole serving your house and, if you take a service, your current line in is replaced with a (heavier) combined fibre/copper cable.
Is there anything on a local road works notification page about planned OR work in your area.
11-07-2020 6:20 PM
OpenReach have put fibre from the green boxes to the poles all around my area and every pole has a couple of large black plastic egg box looking things on top. So it's a very short simple step to drop the fibre from the pole tops to the home, and they have done some already.
17-07-2020 7:35 PM - edited 17-07-2020 7:43 PM
@bmc - no OR related work on any page I can find, and no sign of any poles in the area with the FTTP blocks on them,
I replace the Hub One with a VR600 V2 and now have:
Upstream | Downstream | |
Current Rate (kbps) | 7409 | 35000 |
Max Rate (kbps) | 7409 | 46133 |
SNR Margin (dB) | 6.1 | 10.6 |
Line Attenuation (dB) | 39.1 | 18.4 |
Errors (pkts) | 13 | 0 |
Will be interesting to see what happens connection speed wise in future.
The BT Speed test is reporting the IP Profile for your line is 32.41 Mbps
which is 0.01 more than it was when I started the thread
17-07-2020 8:58 PM
Looks like you are banded at 35Mbps, the high SNRM is a clue. Need to request a DLM reset, best of luck getting it done as Plusnet are not doing much to fix speed faults these days.☹️
18-07-2020 10:37 AM
@Gandalf - how easy is it to get a reset? It looks like the VR600 works a lot better on my line than the Hub One.
Max Rate (kbps) | 7409 | 46255 |
SNR Margin (dB) | 6.1 | 10.5 |
Errors (pkts) | 17 | 0 |
18-07-2020 6:03 PM
20-07-2020 10:37 AM
22-07-2020 7:22 PM
23-07-2020 12:45 PM
Line dropped and reconnected just over 2 hours ago
Current Rate (kbps) | 7495 | 40329 |
Max Rate (kbps) | 7495 | 47755 |
SNR Margin (dB) | 6.1 | 6.3 |
Line Attenuation (dB) | 39.3 | 18.6 |
