is this Unlimited Fibre or Unlimited Fibre Extra?
Fixes: 1,102
Re: is this Unlimited Fibre or Unlimited Fibre Extra?
Thanks for getting in touch @SteveA
I'm sorry for the issues with renewing and your speed.
I can confirm you're provisioned on 80/20. Your package is a legacy one named Plusnet Unlimited Fibre which is the same in every way as the modern day Unlimited Fibre Extra. Unfortunately it looks like the particular system that provides a renewal offer online is confusing the legacy fibre extra package with the current Unlimited Fibre (40/10) package.
If you want to renew your contract on fibre extra I'd recommend calling our customer options team on 0800 013 2632. They may be able to move you to the current fibre extra naming in the process to avoid this issue in future.
With regards to your speed, together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
As a side note,
@Browni wrote:
Going back a few years there was a package called 'Unlimited Fibre' that had 80/20 speeds.
Plusnet's naming convention can lead to some confusion
I believe you're referring to our legacy 40/20 package that was 80/20 capped down by us, which we then withdrew in favour of 40/2 but moved existing 40/20 users on to 55/10 as a goodwill gesture.
Browni
Aspiring Hero
Fixes: 52
No, I was referring to legacy 'Plusnet Unlimited Fibre' but missed the 'Plusnet' prefix.
I rest my case about confusing naming standards 🤣
Ex-Plusnetter now living life in the G,fast lane!
Aspiring Champion
Fixes: 18
@Leapy
Although you would have to change providers you at least have the option of WBC FTTP.
@SteveA
Try your number here to see if there are any plans for your area
www.openreach.com/
SteveA
@bmc  -  only a vague future promise of FTTP,:
Full Fibre (Fibre to the Premises - FTTP)
Technology that supports speeds up to 1Gbps
Faster and more reliable fibre is coming to your area soon. Full Fibre is our fastest technology, but your exact speed will depend on which broadband provider and package you choose. Sign up for news and updates.
It's been "soon" for as long as they've been talking about it.
Leapy
Champion
@SteveA  On my block we already have Full Fibre (Fibre to the Premises - FTTP) Technology that supports speeds up to 1Gbps, although it's only 200mbps up! But I'm hopeful PlusNet can sort out my stuff, so I don't have to leave all you nice people to get some speed. Thumbs_Up (speed OMG I'm beginning to sound like a Junkie) 🤣
SteveA
@Leapy - there is FTTP in the new development about 300 metres from me, but we're still on long dangling overhead wires and rotting wooden poles (and crazy wiring where the cab I'm connected to is a long way away and I have to walk past other cabs (with their FTTC partner cabs) before I get to mine). BT have made it quite clear in the past that they have no intention of improving our connectivity - not even Fibre to the Pole, and as I said FTTP has been "coming soon" since day 1.
Aspiring Champion
Fixes: 18
@SteveA
OpenReach won't waste money sorting the old wired connections if they're planning FTTP. From your posting they are indeed "planning" FTTP so they do "plan" to improve your connectivity - it's just a question of when.
If there's a problem with the poles I suspect these would need to be replaced as part of (or before) a FTTP deployment as the Distribution Point (DP) is hung from the pole serving your house and, if you take a service, your current line in is replaced with a (heavier) combined fibre/copper cable.
Is there anything on a local road works notification page about planned OR work in your area.
Leapy
Champion
OpenReach have put fibre from the green boxes to the poles all around my area and every pole has a couple of large black plastic egg box looking things on top. So it's a very short simple step to drop the fibre from the pole tops to the home, and they have done some already.
SteveA
@bmc - no OR related work on any page I can find, and no sign of any poles in the area with the FTTP blocks on them,
I replace the Hub One with a VR600 V2 and now have:
  Upstream Downstream
Current Rate (kbps) 7409 35000
Max Rate (kbps) 7409 46133
SNR Margin (dB) 6.1 10.6
Line Attenuation (dB) 39.1 18.4
Errors (pkts) 13 0
Will be interesting to see what happens connection speed wise in future.
The BT Speed test is reporting the IP Profile for your line is 32.41 Mbps
which is 0.01 more than it was when I started the thread
RealAleMadrid
Seasoned Champion
Fixes: 38
Looks like you are banded at 35Mbps, the high SNRM is a clue. Need to request a DLM reset, best of luck getting it done as Plusnet are not doing much to fix speed faults these days.☹️
SteveA
@Gandalf - how easy is it to get a reset?  It looks like the VR600 works a lot better on my line than the Hub One.
  Upstream Downstream
Max Rate (kbps) 7409 46255
SNR Margin (dB) 6.1 10.5
Errors (pkts) 17 0
Tibzor
Fixes: 25
Hey @SteveA
I just left voicemail on your mobile. I will retest your line shortly and if sync speed will match or will be really close to current 35Mbps banding I will raise request to perform DLM reset.
You can view and answer to ticket on your account here
Tibzor
Fixes: 25
@SteveA Thanks for your time today.
As discussed,  change should be completed within few days. I have updated ticket on your account here
Leapy
Champion
@Browni wrote:
@Leapy when you get an Openreach engineer out they almost certainly fit a new master socket,
@Browni That is exactly what they did, and we moved the router to the master socket and disconnected two extensions to remove any risk of star wiring.
This is my latest wired speed test 🙂
SteveA
Line dropped and reconnected just over 2 hours ago
  Upstream Downstream
Current Rate (kbps) 7495 40329
Max Rate (kbps) 7495 47755
SNR Margin (dB) 6.1 6.3
Line Attenuation (dB) 39.3 18.6
