frequent disconnections
adamversed
hi, I have been getting frequent disconnections for weeks, here are my line statistics, usually the upload/download rate is a lot higher, I guess this is due to the current maintenance, possibly part of the problem (usually get nearer 55 mb down):
    Receive Direction Send Direction
Max. DSLAM throughput kbit/s 80000 20000
Min. DSLAM throughput kbit/s 128 0
Attainable throughput kbit/s 37760 9947
Current throughput kbit/s 38456 9920
Seamless rate adaptation   off off
Latency   fast fast
Impulse Noise Protection (INP)   35.7 49.9
G.INP   on on
Signal-to-noise ratio dB 7 6
Bitswap   on on
Line attenuation dB 20 26
Profile 17a
G.Vector   off off
Carrier record   A43 A43
I have tried for a sustained period with two different routers, both display the same problem, currently I am using a fritzbox 7390
3 REPLIES 3
MatthewWheeler
Fixes: 480
Re: frequent disconnections
Sorry to hear you're having issues.
Our tests are showing a external fault but as our suppliers systems are down for maintenance until 5pm we can't raise this until then.
 Matthew Wheeler
adamversed
thanks for getting back to me, if you could let me know when the fault has been raised that would be appreciated.
Chris
Legend
Fixes: 169
I've just retested the line now and it's not finding the same issue.
If you continue to have issues I'd advise getting this reported to us as a fault at https://faults.plus.net
