frequent disconnections
- Re: frequent disconnections
20-05-2017 8:07 AM - edited 20-05-2017 8:10 AM
hi, I have been getting frequent disconnections for weeks, here are my line statistics, usually the upload/download rate is a lot higher, I guess this is due to the current maintenance, possibly part of the problem (usually get nearer 55 mb down):
Receive Direction | Send Direction | ||
Max. DSLAM throughput | kbit/s | 80000 | 20000 |
Min. DSLAM throughput | kbit/s | 128 | 0 |
Attainable throughput | kbit/s | 37760 | 9947 |
Current throughput | kbit/s | 38456 | 9920 |
Seamless rate adaptation | off | off | |
Latency | fast | fast | |
Impulse Noise Protection (INP) | 35.7 | 49.9 | |
G.INP | on | on | |
Signal-to-noise ratio | dB | 7 | 6 |
Bitswap | on | on | |
Line attenuation | dB | 20 | 26 |
Profile | 17a | ||
G.Vector | off | off | |
Carrier record | A43 | A43 |
I have tried for a sustained period with two different routers, both display the same problem, currently I am using a fritzbox 7390
20-05-2017 10:33 AM
20-05-2017 7:00 PM
thanks for getting back to me, if you could let me know when the fault has been raised that would be appreciated.
22-05-2017 9:25 AM
I've just retested the line now and it's not finding the same issue.
If you continue to have issues I'd advise getting this reported to us as a fault at https://faults.plus.net
