dslam reset?
- Re: dslam reset?
- « Previous
- 1
- 2
- Next »
Re: dslam reset?
24-07-2017 6:59 PM - edited 24-07-2017 7:11 PM
IMO the plusnet reps in this forum are a better bet. Hopefully one of them will be along before too long.
Re: dslam reset?
24-07-2017 7:03 PM
Here is a list of the Super Users that also may be able to help!
Re: dslam reset?
25-07-2017 10:07 AM - edited 25-07-2017 10:08 AM
@jan Apologies for the delayed response.
Our tests are showing a potential issue on the phone line which may be a cause.
As your phone line is with another provider I'd recommend getting them to run a line test.
Re: dslam reset?
25-07-2017 10:46 AM
Hello,
so I plugged the wired phone that I keep for just this purpose into the master socket & the line is clearly very noisy and you have somehow remotely identified a fault with our line. But when I use the bt online tool to run a line test it says everything is fine and I could be charged £130 if I request an engineer
Why does your test find a fault but BT's doesn't?
Re: dslam reset?
25-07-2017 10:52 AM - edited 25-07-2017 10:59 AM
update:
This bt fault check is so contradictory & ambiguous. after the line test I run through the troubleshooter, which immediately says without apparently any more tests
"The Line Test result indicates that there's a fault in the network near your home. An engineer will check outside first, we don't need an appointment to visit your home at the moment."
Is their first "There's no fault but you can pay £130 to check" just to discourage fault reporting?
Anyway it still says we could be charged and we have to tick a box - I can't work out if it is poor design or designed to scare <sigh>
I'm sure it is not our problem so will go ahead, but my mother would definitely be scared off.
Thanks for your help people, hopefully it will be sorted soon.
[edit] the final bit of utter stupidity is that it displays a confirm details page which has a text field where you can enter any extra details about the fault to help their engineer. If you type anything in that box it disables the confirm button. Another victim of zero planning, agile development and inadequate testing.
Re: dslam reset?
25-07-2017 1:57 PM
@jan wrote:
Hello,
If your line is noisy, that'd be a fault your phone provider would need to report to Openreach. Whilst I can't speak for a third party company, I believe the potential charge they advise of is if the problem doesn't lie with the wholesale network.
One of the main checks we advise to rule out an internal wiring fault is by plugging your equipment into the test socket, as explained here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Our tests show the following:
GEA Test Detail
Circuit ID | NA | Service ID | BBEU######## |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 58.7 Mbps | ||||
Upstream Speed | 19.6 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 463.2 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-67M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-07-12T14:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 58.6 Mbps | 58.6 Mbps | 58.6 Mbps |
Up Stream Line Rate | 19.5 Mbps | 19.5 Mbps | 19.5 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-07-25T13:30:29.144+01:00 | 2017-07-25T13:45:29.144+01:00 |
Ingress Code Violation | 0 | 652 |
Egress Code Violation | 0 | 4 |
Errored Seconds | 25 | 13 |
Severely Errored Seconds | 14 | 1 |
Unavailable Seconds | 0 | 0 |
Re: dslam reset?
25-09-2017 8:26 AM - edited 25-09-2017 8:29 AM
Hello again,
so BT came checked the line, found a fault and have replaced the copper in the street to our house & reset the dslam and I have waited for the training period
However this has not changed my speed test results at all.
The estimate given by plusnet for this address was
Your estimated speed is: Between 60Mbps and 76Mbps
and when it was first connected it did sync at 73mbps.
The router is connected directly to the BT test socket (which is a new one fitted by BT when the broadband was setup) . There are no extensions.
Quality graph
- « Previous
- 1
- 2
- Next »
