anybody have issues with people thinking you live in different country
- Re: anybody have issues with people thinking you l...
20-07-2020 6:19 PM
I have tried to make a couple of purchases from abroad I live in uk and businesses declining my card as I live in Belgium I have checked settings on computer and they are all correct anyone?
Re: anybody have issues with people thinking you live in different country
20-07-2020 6:24 PM - edited 20-07-2020 6:42 PM
It sounds like your external IP is being misclassifed. It is not an exact science.
A staff memember should pick this up and you might have to PM them what it is. Don't post it on here.
Can't remember off the top of my head what site tells you.
EDIT - remembered: http://www.whatismyip.com
See what it says about your ISP.
20-07-2020 6:37 PM
how do I PM plusnet please
20-07-2020 6:39 PM
hi Alex just tried that site and it comes up not working or misspelt or no longer a site
20-07-2020 6:40 PM
If a member of staff replies and takes up the issue you are facing then click on their name and there is a button on the right with "Send Private Message".
20-07-2020 6:43 PM - edited 20-07-2020 6:48 PM
Sorry the link I posted was the https version, so I have edited my post.
Thankfully I was able to edit my post within the 15 minute deadline. So try my link again?
21-07-2020 9:23 AM
hi my isp is fine I checked
VPN
22-07-2020 9:28 AM
cant do transactions at minute card being declined as i dont live in uk but obviously i do could it be because my VPN through plusnet is set to another country so how can i change it please help i am going mad
Re: VPN
22-07-2020 9:36 AM
If your VPN is set to another country then that is very likely to be your problem. You need to either get into your VPN settings and set the destination country to UK or disable it. All VPNs are different so you will have to either tell us which VPN you are using or read the VPN manual.
Re: VPN
22-07-2020 10:53 AM
how do i find out about my VPN please
Re: VPN
22-07-2020 2:29 PM
Is it a special router wirh VPN installed on it? If so what make is it? It can't be a Plusnet hub as they cannot have a VPN installed on ithem so it must be software on your computer.
Who put VPN on your system? Can you ask them?
More fundamentally are you sure that you are running a VPN and if so how you know as this may give us a clue.
If it is a special modem/router then maybe the easiest solution is to temporarily replace it with the Plusnet supplied hub. If it is an Internet browser add on then simply use a different browser.
Re: VPN
22-07-2020 2:33 PM
it is a plusnet hub I didnt understand about VPN it was the two companies abroad said it must be your VPN as it wasnt the bank declining my card
Re: VPN
22-07-2020 2:33 PM
do you have any more ideas why card being declined if its not the bank
Re: VPN
22-07-2020 2:39 PM
Going back to your other thread, did you ever get a resuly from https://www.whatismyip.com/ ?
Does it say who the owner is ?
Re: VPN
22-07-2020 2:42 PM
As @Baldrick1 says, it doesn't sound like you're actually using a VPN.
It's almost certainly the two companies using out of date geolocation data and incorrectly identifying your public IP as not being in the UK.
