Very Slow VPN Speeds
humanoid769
Hi
I use a Liberty VPN Router to help protect my family  and their devices while on the internet but I notice that f I do not use VPN my speeds are 50+ but as soon as I enable VPN it drops down to around 5-10mbps... This makes day to day working and Netflix usage very hard to use.
I have tried other VPN Clients like ExpressVPN, ProtonVPN and PureVPN and they all have the same problem.
Is there something I am missing or do PlusNet throttle VPN Clients?
16 REPLIES 16
Re: Very Slow VPN Speeds
@humanoid769 - I’m no expect but I would think that the provider would determine your VPN’s capacity and would have nothing to do with Plusnet. I would also guess that if you were willing to pay or pay more money they would increase the Upstream / Downstream bandwidth allocated to you.
humanoid769
Thanks for your response @Anonymous The Liberty service and ALL of the others I have tried have been paid services... Each one of them when I have been onto support are saying that it is the ISP .. I am just lost now as it is fine if I attach it to a Virgin Fibre router 😞
That's interesting, I would have thought the opposite, as Plusnet would simply have seen it as a connection so it will be interesting to see what Plusnet have to say on this. I wonder if @bobpullen or anyone else can shed some light on this.
humanoid769
When I spoke with them yesterday I just got an answer "We don't support VPN" on our residential package
Fixes: 1,484
What is very slow speeds?
Whenever you use a VPN then you will always have slower throughput and higher latency.
I used PIA and depending on node / time of day could lose about 8mbit - but that's still plenty of bandwidth for streaming etc.
I'm surprised Netflix works at all - they have blocked most VPN connections now.
Fixes: 1,484
I use a VPN client on the computer rather than a router - have you tried that as well?
humanoid769
Yes I have tried client software as well... The attached picture was using Express VPN on Android and Laptop
humanoid769
Thanks.. I have added a picture to show the difference .. I lose 80% of my speed
humanoid769
another one that believes my ISP is throttling the VPN
ejs
Aspiring Hero
Fixes: 25
Why exactly are you using a VPN? What are you expecting it to protect you against?
It'll stop Plusnet being able to see what you're doing on the Internet, but your VPN provider will be able to see what you're doing instead.
bobpullen
Fixes: 316
I'd need to understand more about how this is set up before offering comment. I assume it's a physical box connected to a router we've supplied? If the VPN device is removed entirely and a software client used then does that help? The Hub One has limitations on the EWAN port that could explain what you're seeing (although the impacted speeds you're reporting are still well below what I'd expect).
Assuming you're on an unmetered residential package, we don't throttle VPN traffic.
humanoid769
Hi @bobpullen
Yes LibertySheild Provide a pre-configured router which you plug into the plusnet router so this created the vpn. I get the same performance wether i used the router or any client software. and i am on Unlimited Fibre Extra
humanoid769
Hi @ejs
I am a freelance consultant and use it to connect to clients sites plus we like to use things like Netflix USA and also I travel a lot so would like to access thinkgs like the BBC iplayer when overseas
bobpullen
Fixes: 316
So when you're using the software client, is the physical device removed from the network? If you can tell me what software clients you've tried then I'm happy to try replicating the issue?
