Upgraded to Unlimted Fibre Extra - no change
Ktulukane
Hello
I'm hoping someone can see this and help me get it sorted.
I upgraded on the 8th Jan  to the unlimited Fibre Extra plan and there has been no change in my download speed. Curiously my up load speed has doubled.
Anyone be able to give me some advice please:)
31 REPLIES 31
Strat
Fixes: 565
Re: Upgraded to Unlimted Fibre Extra - no change
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
newbec
Same thing has happened to me.
My minimum Guaranteed Speed shows as 62.3Mbps yet my Current Line Speed (Download) is set at 40Mbps for some reason therefore im not getting any increase in download speed from what I was getting before.
BT Wholesale test says:
For your connection, the maximum achievable download speed is 70.79 Mbps
IP Profile for your line is 70.79 Mbps
So its Plusnet who are limiting the speed and need to do something their end to remove the restriction.
Fixes: 1,601
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
durrana10
Reboot router to see if that then re syncs at the correct speed.
Ktulukane
Hi there
Thanks for the reply, I did reboot the router and there was no change.
Any other thoughts?
Ktulukane
Hi there, thanks for your response.
I just did the BT Wholesale test and it says I am reaching 36.81Mbps and acceptable is between 27.1 - 38.72.
My IP Profile is 38.72
Does this mean that I am incapable of reaching the speeds that unlimited Fibre Extra says I can?
In which case there is no point me paying the extra.
Any help greatly received
Ktulukane
Anybody?
If these are the speeds I am keeping then fine, but I would just to know so I can stop wasting my time trying to figure it out.
I am hoping your collective wisdom comes through for me Smiley
Thrall
Seasoned Pro
Fixes: 23
Difficult to say based on the information you’ve given. What are the estimates of your line at http://broadbandchecker.btwholesale.com
Also have you raised a fault?
Ktulukane
Hi there
I did the test as you suggested and these are the results I got.
Does this help you guys help me?
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper
High Low High Low
VDSL Range A (Clean)  80 73.2 20 19 66.9 Available Available --
VDSL Range B (Impacted)  80 68.8 20 19 60 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 1000 220 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 19.5 -- 18 to 21.5 Available Available Yes
WBC ADSL2+ Annex M Up to 19.5 Up to 1.5 18 to 21.5 Available Available Yes
ADSL Max Up to 8 -- 7 to 8 Available Available --
WBC Fixed Rate 2 -- -- Available Available Yes
Fixed Rate 2 -- -- Available -- --
Any help greatly appreciated
Also, yes I did do the fault thing with plusnet. I am waiting back for that.
Thrall
Seasoned Pro
Fixes: 23
Your line can achieve between 73mbps and 80mbps so there’s definitely an issue somewhere.
Try plugging your router into the test socket https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Failing that you’d likely need an Openreach engineer to investigate further
Mustrum
Fixes: 77
Posting the table above using your phone number would reveal more information.
As well as the test socket, log into the router and go to the Advanced/Troubleshooting/Help Desk tab and post the results before and after the  test socket - make sure you hide sensitive info.
Ktulukane
Thanks for your info
I have never removed a faceplate before, is it a simple procedure ? I am not likely to ruin anything am I?
Ktulukane
OK.......
So i removed the faceplate of what I assumed was the master socket (as the landlord told me it was the only one in the house that work - after I moved in!). Anyway, I removed the faceplate and there was no test socket behind it.
Ktulukane
Found master socket
Removed face plate, plugged into test socket. No change.
