Upgraded to Unlimted Fibre Extra - no change
- Re: Upgraded to Unlimted Fibre Extra - no change
18-01-2021 1:43 PM
Hello
I'm hoping someone can see this and help me get it sorted.
I upgraded on the 8th Jan to the unlimited Fibre Extra plan and there has been no change in my download speed. Curiously my up load speed has doubled.
Anyone be able to give me some advice please:)
18-01-2021 2:34 PM
This topic has been moved from ADSL Broadband to Fibre Broadband.
18-01-2021 10:10 PM
Same thing has happened to me.
My minimum Guaranteed Speed shows as 62.3Mbps yet my Current Line Speed (Download) is set at 40Mbps for some reason therefore im not getting any increase in download speed from what I was getting before.
BT Wholesale test says:
For your connection, the maximum achievable download speed is 70.79 Mbps
IP Profile for your line is 70.79 Mbps
So its Plusnet who are limiting the speed and need to do something their end to remove the restriction.
19-01-2021 11:23 AM
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
19-01-2021 11:28 AM
Reboot router to see if that then re syncs at the correct speed.
19-01-2021 1:18 PM
Hi there
Thanks for the reply, I did reboot the router and there was no change.
Any other thoughts?
19-01-2021 1:32 PM
Hi there, thanks for your response.
I just did the BT Wholesale test and it says I am reaching 36.81Mbps and acceptable is between 27.1 - 38.72.
My IP Profile is 38.72
Does this mean that I am incapable of reaching the speeds that unlimited Fibre Extra says I can?
In which case there is no point me paying the extra.
Any help greatly received
21-01-2021 2:28 PM
Anybody?
If these are the speeds I am keeping then fine, but I would just to know so I can stop wasting my time trying to figure it out.
I am hoping your collective wisdom comes through for me
21-01-2021 2:39 PM
Difficult to say based on the information you’ve given. What are the estimates of your line at http://broadbandchecker.btwholesale.com
Also have you raised a fault?
21-01-2021 6:40 PM
Hi there
I did the test as you suggested and these are the results I got.
Does this help you guys help me?
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper | ||
High | Low | High | Low | |||||
VDSL Range A (Clean) | 80 | 73.2 | 20 | 19 | 66.9 | Available | Available | -- |
VDSL Range B (Impacted) | 80 | 68.8 | 20 | 19 | 60 | Available | Available | -- |
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process |
FTTP on Demand | 1000 | 220 | -- | Available | -- |
ADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | ADSL Availability Date | WBC SOADSL Availability Date | Left in Jumper |
WBC ADSL 2+ | Up to 19.5 | -- | 18 to 21.5 | Available | Available | Yes |
WBC ADSL2+ Annex M | Up to 19.5 | Up to 1.5 | 18 to 21.5 | Available | Available | Yes |
ADSL Max | Up to 8 | -- | 7 to 8 | Available | Available | -- |
WBC Fixed Rate | 2 | -- | -- | Available | Available | Yes |
Fixed Rate | 2 | -- | -- | Available | -- | -- |
Any help greatly appreciated
Also, yes I did do the fault thing with plusnet. I am waiting back for that.
21-01-2021 6:55 PM
Your line can achieve between 73mbps and 80mbps so there’s definitely an issue somewhere.
Try plugging your router into the test socket https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Failing that you’d likely need an Openreach engineer to investigate further
21-01-2021 7:38 PM
Posting the table above using your phone number would reveal more information.
As well as the test socket, log into the router and go to the Advanced/Troubleshooting/Help Desk tab and post the results before and after the test socket - make sure you hide sensitive info.
22-01-2021 9:09 AM
Thanks for your info
I have never removed a faceplate before, is it a simple procedure ? I am not likely to ruin anything am I?
22-01-2021 9:37 AM
OK.......
So i removed the faceplate of what I assumed was the master socket (as the landlord told me it was the only one in the house that work - after I moved in!). Anyway, I removed the faceplate and there was no test socket behind it.
22-01-2021 10:43 AM
Found master socket
Removed face plate, plugged into test socket. No change.
