Unable to investigate latency of up to 100ms?
Chris
Legend
Fixes: 169
Re: Unable to investigate latency of up to 100ms?
It's only an engineer that can request a line reset, you should find that if the line quality stays good and stable the speeds may increase over time.
mossywell
Yeah - that's the problem. It's not bad enough for PN to ask an engineer to fix it, and because I don't have a contract with BT, I can't ask them either. My perennial frustration with PN is the correlation between "it's not our network" and "we can do nothing about it".
mossywell
Latency graph. The 7-8ms continues to the left. Note how it's actually deteriorated again since BT's fix.
Two questions:
1. Are PN able to ask BT to switch it back to fastpath now that BT have fixed the street cabling problem?
2. Are PN willing to do this?
Fixes: 1,601
Two questions:
Afraid not, we aren't able to make adjustments or reset DLM.
DLM should automatically make adjustments where/if required.
It's not a question of if we're willing. I'd happy do it/arrange for it to be done if it was possible. Currently the only way to reset DLM is for an engineer to contact their DCoE (Diagnostics Centre of Excellence) whilst on the job.
mossywell
Right, but the question wasn't if you can (I know you can't), it's if you can get BT to do it? It seems mad that you can't. When I was on BT, the BT CS people could request it and the same with Sky. It feels sometimes like PN are kept so distant from BT that you capability to provide support is (let's say) severely hampered. From my perspective, it feels like "conveniently distant". Sad
HarryB
Fixes: 256
I'm afraid not.
I don't believe they can on Fibre.
While ISP's can reset DLM on ADSL connections, I believe only Openreach can do this on Fibre connections currently.
http://www.kitz.co.uk/adsl/DLM.htm#DLM_reset :
~ DLM reset
With adsl/adsl2+ products, its possible for the ISP to reset the DLM.
For NGA products (Fibre) then the ISP cannot perform a reset and this can only be done by a BT Openreach engineer after clearance of a line fault.
 Harry Beesley
mossywell
Can you feel my frustration? I say "can you please ask BT to do it?" and you say "we can't do it, only BT can do it." Now, you are an intelligent bunch and I'm sure therefore that you can see the fact that the answer doesn't answer the question?
I think what you are saying is "we can't do it, and we can't ask BT to do it either". But whenever I ask for cast-iron conformation, all I get back is a "we can't do it".
Re Sky, well I know that it happened. So, there is a very simple conclusion: they asked BT to do it?!
HarryB
Fixes: 256
I actually said Openreach.
I also went on to quote Kitz's website which states:
While I do completely understand and also share your frustrations, I am afraid that does not change the fact that this is not something that we can do or request to be done remotely.
 Harry Beesley
