Switching on the 10th: a few questions
- Switching on the 10th: a few questions
03-02-2016 3:14 PM
Does the Hub One connect to the faceplate with standard RJL11 cable? If so I have been looking at a 3m RJ11 lead do I can put the router somewhere more practical. Is such an extension a a bad idea? If not should the cable be shielded?
My ADSL has been flaky at times and I have had best results with Broadcom chipset routers. It seems the Hub One is not Broadcom so I have been looking at the Billion 8800NL. Are there any other routers with Broadcom chipsets worth considering, preferably cheaper than the Billion but at least no more expensive?
TIA
Re: Switching on the 10th: a few questions
03-02-2016 3:27 PM
Yes. However you will probably find that the faceplate and router will actually take an RJ45 ( 8 pin ) connector in which case a standard CAT6 ethernet patch cable will be fine ( and a lot cheaper than an RJ11 one )
Quote If not should the cable be shielded?
03-02-2016 3:37 PM
It now comes with a 2 meter power cable and 2 meter data cable.
03-02-2016 3:57 PM
@ Cedlor: I only ordered today, unsure how long delivery takes for the router
03-02-2016 4:31 PM
Quote from: MisterW Yes. However you will probably find that the faceplate and router will actually take an RJ45 ( 8 pin ) connector in which case a standard CAT6 ethernet patch cable will be fine ( and a lot cheaper than an RJ11 one )
Are you sure about that? I'd be surprised if the modem/router accepted a RJ45 plug in its DSL socket.
03-02-2016 4:54 PM
03-02-2016 5:04 PM
03-02-2016 5:09 PM
http://www.run-it-direct.co.uk/btvdslfaceplate.html
Quote Centralised vDSL filtering is then provided negating the need for plug in microfilters with an RJ45/RJ11 socket providing the connection for a modem/router.
Quote Are you sure about that? I'd be surprised if the modem/router accepted a RJ45 plug in its DSL socket.
Yes, so was I, but I've just connected a TG589n VDSL modem/router in the office and I'm pretty sure that accepted an RJ45 plug in it's VDSL port as well
