Speed reduction with time
- Re: Speed reduction with time
29-04-2017 10:05 PM
Since using a Hub One my speed halves after about 10 days or so and is only cured by power cycling the router. Don't know if it is a router or line fault.
Message 1 of 4
(1,102 Views)
3 REPLIES 3
30-04-2017 8:58 AM
Are the stats given in the router help desk the same when it's working at full speed as when it's slower? If so, it sounds like this issue, it's a router fault.
Message 2 of 4
(1,077 Views)
01-06-2017 7:09 PM
I have replaced the plusnet router with a Netgear D6400 everything now seems OK.
Message 3 of 4
(980 Views)
02-06-2017 9:04 AM
Message 4 of 4
(956 Views)
