Any problems in Lincolnshire
idonno
Just done some speed tests and the upload is about a quarter down on normal  Used to be consistently around the 18.5mb/s mark but currently seem to be languishing in the 13-15mb's on all the sites I've checked. Download speed is reasonable i.e. 60mb/s plus. Congestion?
rongtw
Fixes: 12
Re: Any problems in Lincolnshire
@idonno do you do a lot of uploads ?
a drop of 3mb,s is nowt to worry about
idonno
It can do, depends on how many photos I'm uploading - sometimes hundreds - 12 mb each photo. Time is of the essence :-) I see I'm still stuck in the slow lane this morning, so not congestion at this time in the morning. I had a quick peep at the modem stats last night and it was syncing at 13mb as well. 5db both up and down. Considering I'm on 78/20 something seems to have fallen down - again. While the download has varied and slowly crept down over the past year, upload has always been solid in the high 18mb/s
Todays speed test
rongtw
Fixes: 12
your speedtest looks fine Thumbs Up
look at mine Shocked  https://www.thinkbroadband.com/speedtest/1496295769587040455
Fixes: 163
I'd expect your line to be syncing higher based on the estimates:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 69.1 20 20 60.5 Available -- -- Yes --
If you continue to have issues I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
idonno
Thanks for the reply Chris. I will do. Looks like the gremlins have resurfaced on the line (OR had a couple of goes resolving it only a couple of months ago.
2 speedtests just done (different websites similar results) ..... upload down to 6.8mb :-(
Worse, I see DLM has kicked me into the long grass....47mb/s. I suppose you don't do FTTP in my area yet?
SpendLessTime
Aspiring Hero
Fixes: 69
@idonno
While I doubt it as you have FTTC, you can follow this guide to find out for yourself:-
First you must be an existing Plusnet broadband customer
Then, check with BT if you are able to get FTTP using the BT Broadband checker at http://www.dslchecker.bt.com/adsl/adslchecker.welcome?
The results will need to look like this
If the first line of the "Featured Products" says "WBC FTTP" then you can apply for the trial at http://trials.plus.net/
Another way is to go to the BT Retail website and see if you can buy Infinity 4 from them (FTTP at 330Mbps download). If you can then you can also apply to join the Plusnet trial or use BT or even Zen (the latter 2 offer FTTP as a product not just a trial)
Finally Plusnet only offer 2 speeds for FTTP, 40Mbps down/2Mbps up or 80Mbps down/20Mbps up. Use BT if you want faster.
There is a complete list of all FTTP providers at
Openreach Ultrafast fibre suppliers
Finally VirginMedia are installing some 2 million FTTTP connections via their Project Lightening before 2019 so it might be a consideration if they are planning to install in your area.
idonno
Thanks for that info SpendLessTime Having just done a check, no chance round here then.
Seems I have a fault on my broadband. Just hope things get fixed for the weekend.
