Speed dropping
St3
Aspiring Champion
Fixes: 5
Speed dropping
My speeds have been up and down for the last month now, they normally about 64/19 but as you can see they have dropped abit.
Also btwholesale is showing incorrect readings too.
10 REPLIES 10
Shep41
Seasoned Pro
Fixes: 6
Re: Speed dropping
Wow 512 meg download. That even beats FTTP
Something's wrong somewhere. Can you post your router stats
Strat
Fixes: 565
Re: Speed dropping
The BT wholesale speed tester has been widely criticised for inaccurate results in recent times.
rongtw
Fixes: 12
Re: Speed dropping
@Strat  our @Gandalf  chased up BT ages ago but nowt has happend Sad
Mustrum
Fixes: 77
Re: Speed dropping
Gadalph is off on his tours for most if not all of this month, so don’t expect a response from him for a while.
St3
Aspiring Champion
Fixes: 5
Re: Speed dropping
Hmm i've just taken some more tests and it seams fine now, i wonder if its just peak times bt test is still showing incorrect readings tho
rongtw
Fixes: 12
Re: Speed dropping
@St3 are you using Firefox ?
iangilf
Re: Speed dropping
i remember when antivirus software used to give u bad readings could be that
St3
Aspiring Champion
Fixes: 5
Re: Speed dropping
No i use google chrome and have done for some time.
St3
Aspiring Champion
Fixes: 5
Re: Speed dropping
I just used IE for btwholesale and it show the correct speeds, but when i use chrome 64 it shows download of upto 600meg... so its looking like the latest chrome could be to blame.
rongtw
Fixes: 12
Re: Speed dropping
most likely be because BT still use a flash based test Undecided
