Speed dropping
- Re: Speed dropping
Speed dropping
11-02-2018 9:55 PM
My speeds have been up and down for the last month now, they normally about 64/19 but as you can see they have dropped abit.
Also btwholesale is showing incorrect readings too.
Re: Speed dropping
11-02-2018 10:12 PM
Something's wrong somewhere. Can you post your router stats
Re: Speed dropping
11-02-2018 10:16 PM
The BT wholesale speed tester has been widely criticised for inaccurate results in recent times.
Re: Speed dropping
11-02-2018 10:28 PM
Re: Speed dropping
11-02-2018 11:19 PM
Gadalph is off on his tours for most if not all of this month, so don’t expect a response from him for a while.
Re: Speed dropping
12-02-2018 12:10 AM - edited 12-02-2018 12:40 AM
Hmm i've just taken some more tests and it seams fine now, i wonder if its just peak times bt test is still showing incorrect readings tho
Re: Speed dropping
12-02-2018 7:51 AM
@St3 are you using Firefox ?
Re: Speed dropping
12-02-2018 2:36 PM
i remember when antivirus software used to give u bad readings could be that
Re: Speed dropping
12-02-2018 3:05 PM
No i use google chrome and have done for some time.
Re: Speed dropping
13-02-2018 3:24 PM
I just used IE for btwholesale and it show the correct speeds, but when i use chrome 64 it shows download of upto 600meg... so its looking like the latest chrome could be to blame.
Re: Speed dropping
13-02-2018 5:45 PM
most likely be because BT still use a flash based test
