Speed Up and down
- Re: Speed Up and down
Speed Up and down
30-04-2018 8:14 PM
Hello
For the past few days i have had random speed drops
First test
45 mn later
2h later
so i wonder if there is issues around hyde/ tameside or is it my line? ( or the router again ? already replaced 2 month ago)
01-05-2018 12:15 AM - edited 01-05-2018 12:15 AM
Hi I would ignore the speed tests from BT Wholesale their tester has issues with a few Browsers giving false results, the most important is the IP profile giving during the further diagnostic test which in your case is 72Mb which could be correct for your line but can't say for sure without router stats and line Estimates.
For a Speed test I would use https://www.thinkbroadband.com/speedtest
It's much more reliable tester if your still seeing low results via a wired connection using that tester then further investigation would be required into why that would be.
01-05-2018 1:41 PM
01-05-2018 4:01 PM
it's always wired ,but seems a bit more stable today
01-05-2018 4:22 PM
