Speed Up and down
sebjo
Speed Up and down
Hello
For the past few days i have had random speed drops
First testFirst test45 mn later45 mn later2h later2h later
so i wonder if there is issues around hyde/ tameside or is it my line? ( or the router again ? already replaced 2 month ago)
4 REPLIES 4
Terranova667
Fixes: 5
Re: Speed Up and down
Hi I would ignore the speed tests from BT Wholesale their tester has issues with a few Browsers giving false results, the most important is the IP profile giving during the further diagnostic test which in your case is 72Mb which could be correct for your line but can't say for sure without router stats and line Estimates.
For a Speed test I would use https://www.thinkbroadband.com/speedtest
It's much more reliable tester if your still seeing low results via a wired connection using that tester then further investigation would be required into why that would be.
adamwalker
Fixes: 221
Hi Sebjo, was that over a wired or a wireless connection to the router?
 Adam Walker
sebjo
it's always wired ,but seems a bit more stable today
adamwalker
Fixes: 221
OK, glad to hear that.
I've run a full set of broadband diagnostics and everything looks good but do shout up if you have any problems again.
 Adam Walker
