Router supplied for Fibre upgrade
- Router supplied for Fibre upgrade
18-10-2015 5:14 PM
Hi - I will be receiving my upgrade pack soon to move from ADSL to fibre and currently have a TG582n with firmware 8-4-4-J.
What router will I get in the pack? I would prefer to use the old one as it is part of a network including a PVR , media server and a bridge and the config was worked out a long time ago.
It would be great if I could just upgrade the firmware.
Is that possible without losing the config - which is saved btw
thanks
Grant.
thanks
Grant.
Message 1 of 3
(781 Views)
2 REPLIES 2
Re: Router supplied for Fibre upgrade
19-10-2015 11:49 AM
Hi Grant
The new router currently being sent out for Fibre services is the Sagemcom 2704N, this unit can be used on both ADSL and Fibre connections and some forum users have been hacking away at it to allow further settings changes if you would like a more advanced network : https://community.plus.net/forum/index.php?topic=137629.0
Message 2 of 3
(399 Views)
19-10-2015 2:21 PM
Thanks for the info - think i'll trawl around for something more versatile and user friendly
regards
Grant.
regards
Grant.
Message 3 of 3
(399 Views)
