Plusnet - is anyone else's wifi signal terrible?
jessicajms
I can't get wifi connection through my whole house. I tried all of plusnet's "helpful" suggestions and nothing works. When I called them they told me that wifi signal is nothing to do with them! Has anyone else had this issue?
bill888
Seasoned Pro
Fixes: 24
Re: Plusnet - is anyone else's wifi signal terrible?
For comparison purposes, what wireless router did use in the house before you installed the new Plusnet fibre router?
Fixes: 21
Welcome to the Forum Jessica. I think the context of Plusnet saying "the wifi signal is nothing to do with them" rather depends. After all if it's a Plusnet supplied router is definitely has "something" to do with them, perhaps not "everything".
Fixes: 65
@jessicajms
Sorry to hear about this,  I'm unaware what you've tried so far so I just want to make sure you've gone through everything listed here: http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml
 Adam Walker
