Plusnet self install coming very soon?
- Plusnet self install coming very soon?
01-05-2015 12:09 PM
BT Wholesale announced yesterday they are commercially launching two new commercial fibre products from 1 June:
Will Plusnet be launching their self install service on the back of this (assuming they have a working and conformity passed FTTC modem/router)?
Quote - FTTC Self Install
- FTTC Managed install using a Customer Provided Modem/Router.
Message 1 of 9
(1,471 Views)
8 REPLIES 8
Re: Plusnet self install coming very soon?
01-05-2015 12:13 PM
No news at the moment I've afraid, when we have something to announce we'll make sure to tell you.
Message 2 of 9
(764 Views)
01-05-2015 12:14 PM
can you clarify what is meant by - FTTC Managed install using a Customer Provided Modem/Router. - as a managed install implies that an engineer will attend and that the ISP will provide the modem instead of him arriving with it
Message 3 of 9
(764 Views)
01-05-2015 12:23 PM
@ Chris - We await with eager anticipation.
@ Oldjim - That's what it will be. The engineer will fit the VDSL front plate to the NTE5 and use the ISP supplied router/modem instead of supplying an OR modem.
Message 4 of 9
(764 Views)
01-05-2015 12:27 PM
so is that in addition to the existing managed install until September (I thought I remembered that date) when it will be withdrawn
Message 5 of 9
(764 Views)
01-05-2015 12:44 PM
OR have extended it a bit, so from 1 Jan 2016 they will no longer supply OR modems for new installs. However, they will continue to support the existing OR modems (i.e. replace faulty ones as part of a repair fault) until 1 Jan 2017.
Message 6 of 9
(764 Views)
01-05-2015 12:48 PM
thanks - that means that I will - no doubt - get a BT Modem
Note to self
Make sure I can spot the difference between an Ecl and Huwai unit
Note to self
Message 7 of 9
(764 Views)
01-05-2015 1:17 PM
Quote Make sure I can spot the difference between an Ecl and Huwai unit
It's all in the spelling Jim.
Message 8 of 9
(764 Views)
01-05-2015 1:19 PM
Very true which is why I will use this to check https://support.aa.net.uk/FTTC_Modem
Message 9 of 9
(764 Views)
