Modem Settings
Neilj
Modem Settings
Hello All,
I have a TP-Link WD9980 VDSL modem router on it's way and was wondering if anyone would be able to give me either a hint as to how to find the modem settings from the OpenReach modem OR let me know what the settings are so I can set it up and hopefully get away form this having multiple boxes to do the job of one.
Thanks in advance for your help
Fixes: 62
Re: Modem Settings
Neilj
Re: Modem Settings
I looked at this but this doesn't seem to be the actual VDSL modem settings (unless I'm missing something - a possibility)  Smiley
Fixes: 62
Re: Modem Settings
It does when read in conjunction with the Setup Manual  for the router http://www.tp-link.com/resources/document/TD-W9980_V1_QIG_7106504333.pdf
Neilj
Re: Modem Settings
You're a star, thanking you kindly.  Smiley
