Plusnet Hub One - Disable NAT or Enable Bridge Mode?
- Plusnet Hub One - Disable NAT or Enable Bridge Mod...
- « Previous
- 1
- 2
- Next »
Re: Plusnet Hub One - Disable NAT or Enable Bridge Mode?
21-09-2016 11:23 PM
Regrettably I'm not a mind reader and don't know the layout of your house You could test the Pi by moving it to where router 2 is perhaps?
If the Windows PC is behaving correctly ignore anything to do with router setup and concentrate on getting your powerline adapters working...
on 21-09-2016 11:24 PM - last edited on 22-09-2016 12:51 AM by Mav
The pi works fine when connected to Router 2, but then again that's directly to the router without the powerline.
The powerlines work fine when I connect my laptop to it, so I can't understand what's going wrong.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules
- « Previous
- 1
- 2
- Next »
