Openreach make change G.INP & IP Profile on huawei cabinet
- Re: Openreach make change G.INP & IP Profile on hu...
- « Previous
- 1
- 2
- Next »
Re: Openreach make change G.INP & IP Profile on huawei cabinet
13-11-2017 4:28 PM - edited 13-11-2017 4:30 PM
I am sick of tired with DLM system. Time to ask BT to scrap it. You don't need DLM for fibre for god's sake.
Interleave depth 8 4 INP 52.00 55.00 INPRein 1.00 1.00 Delay 0 0 Bearer 1 Interleave depth 3 1 INP 4.50 4.00 INPRein 4.50 4.00 Delay 3 0
13-11-2017 4:51 PM
Test Outcome | Pass | |
Test Outcome Code | GTC_FTTC_SERVICE_0000 | |
Description | GEA service test completed and no fault found . | |
Main Fault Location | OK | |
Sync Status | In Sync | |
Downstream Speed | 70.8 Mbps | |
Upstream Speed | 19.1 Mbps | |
Appointment Required | N | |
Fault Target Fix Time | ||
Fault Report Advised | N | |
Estimated Line Length In Metres | 248.3 | |
Upstream Rate Assessment | Very Good | |
Downstream Rate Assessment | Reasonable | |
Interference Pattern | Regular Interference Observed Daily | |
Service Impact | Retrains Observed | |
Interference Duration Longest Occurrence | From 01:30 to 01:45 | |
Interference Location | Unknown | |
Home Wiring Problem | Not Detected | |
Downstream Policing Discard Rate | 0.0 | |
Customer Traffic Level | Upstream and Downstream Traffic Detected | |
Technology | VDSL | |
Current 15Min Bin Retrains | 0 | |
Last 15Min Bin Retrains | 0 | |
NTE Power Status | PowerOn | |
Voice Line Test Result | Pass | |
Bridge Tap | Not Detected | |
Radio Frequency Ingress | Not Detected | |
Repetitive Electrical Impulse Noise | Not Detected | |
Cross Talk | Not Detected | |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | |
Time Stamp | 2017-10-31T15:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 73.9 Mbps | 79.9 Mbps | 79.6 Mbps |
Up Stream Line Rate | 19.9 Mbps | 20.0 Mbps | 19.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 885.0 Sec |
Retrains | 0.0 | 80.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-11-13T14:58:17Z | 2017-11-13T15:13:17Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
13-11-2017 4:57 PM - edited 13-11-2017 4:58 PM
I don't understand the GEA Test say max sync is 79.9/20.0 but the sync rate 70.8/19.1 while my billion modem sync rate is 73998K/20000K.
Look like I was banded indeed.
I will ask the fault team to send out engineer to reset the DLM of my request.
13-11-2017 4:59 PM
13-11-2017 5:45 PM
The timestamp suggests that profile information is about two weeks old! Obviously the line is currently banded and on a Retransmission High profile. Not that that should make any difference to the sending out of Openreach just to do a DLM reset.
13-11-2017 6:42 PM
All DSL needs some sort of DLM system. More so FTTC. A heck of a lot of lines would be in trouble without it.
Anoush. As per ejs comments, that line definitely looks banded to me.
The profile shown in your tests is not current to the line, there are several pointers showing that the data is old.
No way is that line profile Re-TX low and upstream error protection off.
Re-tx is high on downstream. Upstream has Re-TX... and its looks like its banded at 74Mbps.
I've brought this up numerous times in the past that the Profile shown when running a GEA test is not always the most current. I've even seen it on my own line where profile data is out of date.
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Can you by any chance get the ILQ counter status?
That would be interesting to see.
13-11-2017 6:51 PM
But you haven't got fibre!
13-11-2017 9:05 PM - edited 14-11-2017 2:12 AM
@Gandalf Please don't blame me. We got our power loss in my area for about 2 hours. There seem an engineer working on the public footpath by fibre cabinet. Western Power online say it was due to high voltage caused power outage. Please see openreach report on new DLM reset here: https://www.openreach.co.uk/orpg/home/updates/briefings/super-fastfibreaccessbriefings/super-fastfib...
14-11-2017 12:31 PM - edited 14-11-2017 12:38 PM
@Gandalf the GEA Test is outdated, incorrect one.
This is my router stats as of now:
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 33204 Kbps, Downstream rate = 91584 Kbps Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 73998 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 10.5 14.2 Attn(dB): 11.4 0.0 Pwr(dBm): 12.5 -1.0 VDSL2 framing Bearer 0 MSGc: -6 -6 B: 146 81 M: 1 1 T: 0 0 R: 8 8 S: 0.0630 0.1295 L: 19683 5560 D: 8 4 I: 155 90 N: 155 90 Q: 8 4 V: 4 1 RxQueue: 140 135 TxQueue: 35 27 G.INP Framing: 18 18 G.INP lookback: 31 27 RRC bits: 24 24 Bearer 1 MSGc: 154 58 B: 0 0 M: 2 2 T: 2 2 R: 16 16 S: 6.4000 16.0000 L: 40 16 D: 3 1 I: 32 32 N: 32 32 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 0 OHFErr: 0 0 RS: 3606061968 460967 RSCorr: 199 378 RSUnCorr: 0 0 Bearer 1 OHF: 3549696 418353 OHFErr: 0 0 RS: 35496342 1371423 RSCorr: 3 3 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 105590 45 rtx_c: 16 496 rtx_uc: 0 63514 G.INP Counters LEFTRS: 0 15 minEFTR: 73976 20000 errFreeBits: 64370466 75231982 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 3818813807 0 Data Cells: 18915811 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 AS: 57027 Bearer 0 INP: 52.00 55.00 INPRein: 1.00 1.00 delay: 0 0 PER: 0.00 0.00 OR: 0.01 0.01 AgR: 74377.87 20184.26 Bearer 1 INP: 4.50 4.00 INPRein: 4.50 4.00 delay: 3 0 PER: 16.06 16.06 OR: 79.68 31.87 AgR: 79.68 31.87 Bitswap: 55/55 167/167 Total time = 15 hours 50 min 53 sec FEC: 199 378 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 5 min 53 sec FEC: 0 15 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 15 hours 50 min 53 sec FEC: 199 378 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 15 hours 50 min 25 sec FEC: 199 378 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
16-11-2017 11:32 PM - edited 16-11-2017 11:38 PM
@Gandalf Can I have another GEA Test to see if BT system has updated it. I have left the VDSL modem ON at all times and hopefully DLM will restoring my full line back to 79999k/20000k within next 7 days.
However this is my latest router stats after 3 days 2 hours and 44 mins ongoing connection as of today at 23:30
18-11-2017 10:12 AM
Technology | VDSL |
Time Stamp | 2017-11-05T10:15:00 |
Down Stream Line Rate | 73.9 Mbps | 79.9 Mbps | 77.3 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 877.7 Sec |
Start Time Stamp | 2017-11-18T09:43:46Z | 2017-11-18T09:58:46Z |
It doesn't look like anything has changed. I'd ignore the timestamp above. If you look at the Current Traffic Count, you'll see I completed the test within the last 15 minutes.
I hope this helps.
18-11-2017 10:20 AM
It's clear that DLM has banded my line completely because BT system time stamp is outdated.
what is this 80.0?
18-11-2017 10:22 AM
21-11-2017 12:54 PM
@Gandalf any chance re-test of gea test to see if bt system has updated it.
Here is my latest stats from modem as of now after ongoing connection 7 days 16 hours stable.
- « Previous
- 1
- 2
- Next »
