New line appears to have a fixed data rate well below the maximum data rate
marsom
I've recently moved by Plusnet service and upgraded it at the same time as my new line is capable of faster speeds than my old line.
I'm not getting anywhere near what I thought i would on speed tests (attached) so reviewed the router settings and as you can see (attached image) my data rate appears to be capped at 9995/40000. My maximum data rate is currently showing 15595/57440. I know this is a calculated maximum but the actual data rate strikes me as a human entered cap and not something system generated as a capability.
My speedtests appear to be in line with the lower speed fibre product too which makes me more concerned there is something not right.
I checked with the account team and I am definitely on the faster product, could someone confirm why my data rate appears to be capped?
7 REPLIES 7
Mustrum
Fixes: 77
Re: New line appears to have a fixed data rate well below the maximum data rate
You are not on the faster product, CS have lied to you.
You can double check by running the BTW speed test, it will show your max available speed.
Fixes: 398
@marsom sounds like your account got changed BUT the order to Openreach to change the line to 80/20 never got placed.
marsom
Thanks for the info. Do plusnet CS or tech support watch this forum or do I need to contact them directly to check?
This is after the activation of the line happened 6 days after I was originally told it was going to, Plusnet CS really do struggle some times.
Fixes: 398
No but the PN help team do, although they seem a bit thin on the ground recently. I'd try calling CS and making sure they're aware that you are synching at 40/10 . They ought to do a GEA test to check and that will confirm that you are provisioned incorrectly on 40/10.
marsom
Seems they are too busy and the line is cutting off after asking to call them back another time.
Fixes: 398
You could try raising a fault at https://faults.plus.net
marsom
I've done that for now thanks!
