New Customer Speed dropped
Fixes: 1,602
Re: New Customer Speed dropped
Thanks for the screenshot
It's really odd that we can't seem to explain, as your speeds are within expectations we can't investigate further as the only other option we have available is an engineer visit. I'd keep an eye on things and hopefully your speed will improve further.
jb68
I’ll wait until the 10 days is past and if the throughput speed hasn’t increased I’ll use the method to cap my line to reduce the errors to force it to go RTX-low. :).
Optimatts
Fixes: 19
Hi @jb68
If you're still noticing problems after the 10 days just drop us a further comment here and we'll look into this further.
As @Gandalf mentioned, It's likely at that point we may need an engineer visit.
jb68
HI,
Looks like I have sorted it and all looks good
Can you do a GEA Test and check sync and everything is okay. Thanks
RandallFlagg
Fixes: 75
Hi @jb68
Delighted to confirm that the GEA test is showing your sync speed at 80mb/s. I've added a copy of the GEA test to your open ticket here.
Smiley
If there's anything else you need, just drop us a line.
Take care
Dave
jb68
Yeah, all looking good. Impressed.
RandallFlagg
Fixes: 75
Pleased to hear that @jb68 - anything else you need, just drop us a line.
All the best
Dave
