Intermittent ping, loss of packets
- Intermittent ping, loss of packets
15-06-2019 8:50 PM
I have tried changing routers and plugging directly into master socket with no success, seems to happen more in the evening.
If someone can do a test and I think I would need an engineer to sort it out
Re: Intermittent ping, loss of packets
16-06-2019 2:30 PM - edited 16-06-2019 2:31 PM
Hi @bombermanuk1, welcome to the forum.
Hi there, I've had a check of the connection and there definitely seems to be something out of place somewhere as GEA service test failed as shown below, although our tests aren't picking up exactly what's causing the issue so we will have to do some troubleshooting to start ruling things out as it could be caused by something internal.
GEA Test Detail | |||
Circuit ID | NA | ||
Test Outcome | Fail | ||||
Test Outcome Code | GTC_FTTC_SERVICE_1615 | ||||
Description | Potential HR Joint or wet joint detected on GEA Service. Please continue to submit a trouble report | ||||
Main Fault Location | CE | ||||
Sync Status | In Sync | ||||
Downstream Speed | 48.9 Mbps | ||||
Upstream Speed | 14.7 Mbps | ||||
Appointment Required | Y | ||||
Fault Report Advised | Y | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 663.8 | ||||
Upstream Rate Assessment | Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed on Weekends | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 12:15 to 12:30 | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-49M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-06-03T14:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 35.0 Mbps | 49.0 Mbps | 48.3 Mbps |
Up Stream Line Rate | 10.7 Mbps | 14.6 Mbps | 14.1 Mbps |
Up Time | 735.0 Sec | 900.0 Sec | 899.3 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-06-16T12:43:08Z | 2019-06-16T12:58:08Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
We would need to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here
If the problem still persists from here we will go down the route of raising a fault, please click here to raise the fault and let us know once you've done it so we can progress the fault for you.
19-06-2019 9:35 PM
I have ruled out internal wiring by plugging in router directly to master socket behind the face plate. I have also tried with several devices on the network each having the same issue (wired and wireless).
I have put a fault on in my profile but so far it has not been acknowledged, could you give me any further details?
20-06-2019 10:56 AM
Sorry for the delayed response, I've added a reply to your fault ticket now. Once you've responded with the requested information if you can nudge us over here we'll be happy to try to get this picked up a little sooner.
06-07-2019 9:06 PM
On the same note, always good practice to have a confirmation box for things like close actions
on 07-07-2019 8:19 AM - last edited on 07-07-2019 9:21 AM by Mav
Plus net. I am really quite annoyed at your processes and tone of this email. This is e is not resolved!!
have followed all steps and have an engineer booked to resolve the issue. Open the ticket again and do not close until resolved!
Your speed fault
Hello colin,
During the investigation of your reported fault we asked you to complete some steps to help us diagnose the problem. You have reported that you are unable to do so.
As such, we're unable to continue the investigation so have had to close the query.
This also means you will not have the right to leave your contract without paying any cancellation fees at the end of the 30 day period from the date you raised the fault, or the date we have set out in previous emails.
If you are still concerned about your speeds, please use our online speed tester at: http://www.speedtest.btwholesale.com/ (more info) and we have some advice on the things which can affect broadband speeds on our help pages.
Kind regards,
Plusnet Customer Support
www.plus.net
Moderator's note by Mike (Mav): Several posts released from Spam Filter and duplicates removed.
Moderator's note by Mike (Mav): Quote fixed.
07-07-2019 8:25 AM
I would also like to state that my right to leave timescale remains the same as I have indeed followed all the steps
