Monthly usage
biggles001
Monthly usage
Since last Thursday,my broadband usage has indicated zero,anyone got an idea why this should be? I like to check it,just in case my router has been hacked,which doesn't appear to be the case.Trying for an explanation here,rather than have to wait on line.
5 REPLIES 5
acr
Re: Monthly usage
I have exactly the same problem with zero usage since 24 Nov. It seems to happen quite regularly and I have given up doing anything about it. It always seems to correct itself at some point.
MrSilver
Fixes: 9
Re: Monthly usage
Hi Biggles,
@bobpullen can hopefully shed some light on it.
Are you on a capped or uncapped product?
Thx MS
biggles001
Re: Monthly usage
Uncapped,but can't understand why this has happened after being one year into a two year contract!
MrSilver
Fixes: 9
Re: Monthly usage
I wouldn't worry too much, over the past couple of years it's stopped working a couple of time and then comes back later!
bobpullen
Fixes: 316
Re: Monthly usage
@biggles001, it's due to this.
