Upgrade from ADSL
Beermonsta
Upgrade from ADSL
Ive just (Friday 25th) decided to upgrade my connection and wondered a few things, Im due to go live on the 2nd, will my router be posted out in time, and on my member centre, the fibre order is dated 01/01/1970 is this anything to be concerned about?
Thanks In Advance Smiley
12 REPLIES 12
Anoush
Aspiring Hero
Fixes: 139
Re: Upgrade from ADSL
Hello there,
The router should arrive in time and I'd say that that date isn't something to be worried about.
If you private message me with your username I'll be happy to check up on the order for you tomorrow morning when I'm in the office.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Beermonsta
Thank You Anoush, PM sent
Anoush
Aspiring Hero
Fixes: 139
Thank you for your PM.
I can confirm your fibre order is in progress, but for the 08/12/2016. It's been pushed back by Openreach due to engineer availability in your area I'm afraid. The service will go live at any point up to midnight on the day and you may need to reboot your router afterwards.
Beermonsta
Good Morning!
Thanks for the update Anoush
I cant say that I'm surprised about Openreach, recently they have been about as much use as a chocolate teapot in my area, but it does give me a little more time to get things prepared for the switchover!
Thanks again.
Anoush
Aspiring Hero
Fixes: 139
No probs, sorry for the delay. I've just remembered I didn't check up on your new router order; they are usually ordered automatically so should be OK but I'll confirm tomorrow.
Beermonsta
No worries Anoush, with the OP pushback, it gives the equally useless Royal Mail to get their act together!
Anoush
Aspiring Hero
Fixes: 139
Your notification just reminded me to check your account now. I've ordered your router manually now so you should get this within the next 3-5 days, in time for the fibre activation.
Beermonsta
Just got the email to say that my fibre connection is live, but was not due to go live till the 8th.
Could you please check the status of my order before I start to connect things up!!!
Mustrum
Fixes: 77
If you ADSL is still working then the upgrade probably has not gone through yet. We have seen a few examples of that email going out early recently.
That said if you now have your Hub One, then you could connect it up now or over the weekend ready for the 8th, they work with ADSL and VDSL.
Fixes: 400
Ignore the email, it's wrong!. Your account has changed to Fibre but the actual upgrade won't happen until the date Anoush gave you.
RealAleMadrid
Aspiring Hero
Fixes: 59
You've probably received the notorious "Your broadband product change is now complete" email which does not mean you have been upgraded yet. No wonder support is so busy with these confusing e-mails. Your account type has changed but you will not get fibre until BT connect it up in the cabinet. I've had the same myself, ordered an upgrade got the e-mail but after chasing PlusNet they tell me there is a problem with the order which should be resolved by today but no response yet. Looking at the broadband checker says fibre will not be available until 17th January - not looking good.Sad
Beermonsta
Thanks for the clarification guys, much appreciated..I thought it was a bit weird seeing that I can actually see my cabinet from my living room and no-one had been near it!
Ill leave connecting up the Hub One till I go live properly, I have to get my moneys worth out of this Netgear router!!
