Line Check Please
- Re: Line Check Please
Line Check Please
10-11-2015 7:43 AM
Been getting a lot of disconnects over past few days and ran the BT Wholesale checker this morning
My IP Profile seems to be getting lower and lower each time I run the check. Used to always get around 22Mbps and when I ran it yesterday I got this: IP Profile for your line is - 15.28 Mbps
Could someone at PlusNet please run a line check for me?
Thank you.
1. Best Effort Test: -provides background information.
Download Speed
7.31 Mbps
0 Mbps 12.01 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.31 Mbps
For your connection, the acceptable range of speedsis 8.41 Mbps-12.01 Mbps .
Additional Information:
IP Profile for your line is - 12.01 Mbps
Upload Speed
0.09 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 0.09Mbps
Upstream Rate IP profile on your line is - 10 Mbps
Thank you.
Message 1 of 7
(1,221 Views)
6 REPLIES 6
10-11-2015 9:24 AM
I'm going to be honest and say I'm really not surprised your speeds have dropped from the sheer volume of disconnections the last 2 days:
The vast majority of the disconnections seem to happen at 1 minute 20seconds (give or take 5 seconds).
Stopping those disconnections is important before even looking at any speed problems. Has anything changed locally (either in your premises or local area) over the last 3 days? New electrical equipment, roadworks etc maybe.
Message 2 of 7
(926 Views)
10-11-2015 9:41 AM
Cheers Chris.
Wow I knew it had been bad, but not that bad.
Only addition to the house has been an IP camera 2 weeks ago.
Haven't seen any road works either.
Message 3 of 7
(926 Views)
10-11-2015 10:40 AM
Dont think it has bearing on the problem, but on checking my routers settings I came across this:
I've unchecked it now.
- Delay disconnection by provider to the period between [3 - 4]
Message 4 of 7
(926 Views)
10-11-2015 11:24 AM
Good spot and it's worth seeing if it makes a difference. I can see our faults team have got your ticket so they'll investigate and respond asap.
Message 5 of 7
(926 Views)
10-11-2015 5:05 PM
Currently disconnected and seen it go up and down all day.
Run team-viewer on computers at home and have seen them come on line multiple times.
Message 6 of 7
(926 Views)
11-11-2015 11:14 AM
Changing that option in the router has made no difference.
Still getting multiple disconnects.
Attached the Fritz!Box log. It may be of help...
Message 7 of 7
(926 Views)
