Line Check Please Powercut induced Speed Change
- Re: Line Check Please Powercut induced Speed Chang...
13-08-2015 12:52 PM
One hell of a thunderstorm, almost as dark as night during the day at its worst and Torrential rain. A general power cut lasting about an hour knocked out broadband (and cabinet, I reckon). Four weeks of steady speed 37.2Mbps down, and 11.0 Mbps Up has changed to 34.5 Down, 12.7 Up, oddly. I have difficulty with speed variation where its sat steady, I get annoyed whenever I lose speed, just me I guess, a flaw but I can't help it.
I know its not much, but with VDSL2+ it seems almost anything upsets the Apple Cart, so very touchy.
Can you check my line please PlusNet if anything amiss.
Message 1 of 3
(410 Views)
2 REPLIES 2
Re: Line Check Please Powercut induced Speed Change
13-08-2015 1:12 PM
Downstream Speed 46.9 Mbps
Upstream Speed 15.0 Mbps
Your line is in sync above the speeds you're seeing, so nothing restricting you at all. There's no issues showing on a line test either.
Message 2 of 3
(241 Views)
13-08-2015 1:15 PM
Many Thanks Chris.
Message 3 of 3
(241 Views)
