Is it ok to manually reset my router daily if necessary.
- Re: Is it ok to manually reset my router daily if ...
18-08-2021 11:08 AM
Re: Is it ok to manually reset my router daily if necessary.
18-08-2021 11:55 AM - edited 18-08-2021 11:58 AM
@khkats It is not really advisable - DLM could see this as an errorring connection and band your connection. Standard response follows:-
For Community members to be able to help, information from these two sites:-
BT Broadband (obscuring your phone number) and BTW Performance Tester - Please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
18-08-2021 12:04 PM
The key question here is are you saying that your speed over a wireless connection is dropping? If so is the same happening if you connect a computer to the hub using an Ethernet cable? If it’s not then this is a wireless, not a network problem.
18-08-2021 12:10 PM
18-08-2021 2:28 PM
18-08-2021 2:43 PM
Many people have had issues with WiFi on the Hub1, there is an upgrade program going on, but if you are not on the latest version you could request it.
18-08-2021 3:33 PM
18-08-2021 4:01 PM
Read then add a request ti this topic. https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510
18-08-2021 4:03 PM
Log into the router, go to the advanced tab, then troubleshooting, then Help Desk, it will say what version you are on there.
18-08-2021 4:35 PM
18-08-2021 4:42 PM
18-08-2021 5:25 PM
Good on you. Alas you are on the firmware that has caused issues for some others.
It should be updated at some time - no timetable available, or you could try tagging @bobpullen asking for the update, on the thread tagged above and you may get it sooner.
18-08-2021 11:16 PM
18-08-2021 11:45 PM
If you just go to the last post @Baldrick1 has linked, .page 174 and ask for the update he should do it when he gets a chance.
