Internet suddenly no longer working?
- Re: Internet suddenly no longer working?
05-07-2020 7:45 PM
05-07-2020 7:58 PM - edited 05-07-2020 8:01 PM
Welcome to the forums,
The first thing to do is remove any other things that are attached to your line. So of course landline phones, extentions or anything else. They may have gone faulty affecting your line. So rule that out.
Then try the router in the test socket. Just means unscrewing the master socket.
See if it makes any difference. Also, do you notice any noise on your landline? A 17070 option 2 quiet line test will tell you.
If you notice any noise, you will need to raise a fault with your phone provider. If you don't, then you will have to raise a fault with PlusNet.
05-07-2020 8:00 PM
05-07-2020 8:04 PM - edited 05-07-2020 8:05 PM
Fair enough @ryanh2112
It could be the router has died - or there is a fault on your line.
A new router may fix it, just check if you notice anything wrong on the landline. Including the 17070 quiet line test and the whole point of it being you hear no noise. It has happened to me once (lots of noise) and that is what I did and had to report it to BT.
EDIT: If you don't have a landline try and buy a chepo landline phone you can to perform that test.
05-07-2020 8:06 PM
05-07-2020 8:32 PM
If you haven't got a landline you will have no broadband, I assume you mean you haven't got a landline phone, it is a useful thing to have just to check if your phone line is working because if it isn't your broadband may fail.. I am of a certain advanced age and use the phone line to make and receive phone calls, this seems to be a rare thing for younger generations.😃
05-07-2020 8:50 PM
Yep that's what I mean .. I would go somewhere (like your local Argos for example) and I think you can pick one up for £8.
You need to rule out a landline problem if you don't have one first.
08-07-2020 4:15 PM
Hi @ryanh2112, I'm sorry for the issues.
It looks like your connection returned later in the evening; testing the line hasn't highlighted anything that may have caused this.
If you do have any further issues, please just get back to us.
