Internet dropped
- Internet dropped
Internet dropped
11-11-2018 3:20 AM
Hi, my internet dropped out for a few minutes just now (around 3:15am).
Anything showing as to the cause?
Note that I haven't disconnected in about ~7 weeks now prior to this, I just really appreciate a completely stable connection due to my work.
Regards
Afran
Re: Internet dropped
12-11-2018 10:24 AM
Hi @Afran,
I'm sorry for any inconvenience that this drop caused you. As it was just the one drop, it's difficult to determine what's caused this.
Please be aware that, due to the physical nature of the broadband network, we are unable to guarantee a completely stable connection with no drops and it is normal to experience occasional drops. Please let us know if the drops become more frequent.
14-11-2018 2:20 AM
Hi @EmilyD
My connection dropped again tonight, at about 2:15am.
Should I go ahead and raise a fault?
Regards
Afran
14-11-2018 1:38 PM
I've just checked your account and we're only seeing 3 or 4 drops over the course of the past week so as Emily mentioned this can be quite normal.
If you do notice the connection starting to drop a lot more frequently, i.e a number of times a day then do let us know so we can have another look but in all honesty there doesn't seem to be an issue.
14-11-2018 7:11 PM
Hi Adam,
Sorry but, 3-4 drops per week is acceptable? Since when? I've been with Plusnet for over 6 years now and this has never been the standard nor what I would view as acceptable
The odd drop here or there I can totally understand but surely several per week is indicative of something being not quite right.
15-11-2018 12:34 PM
Hi @Afran,
Below is a graph which displays the drops in your connection, the drops being horizontal lines with green dots at the top.
I'm afraid that the drops are not frequent enough for our suppliers to class this as a fault. As no external fault has been detected, the only option we have is to arrange an engineers visit. The time-slots for an engineers visit are weekdays either 8am - 1pm or 1pm - 6pm so it is unlikely they would be able to detect a fault when testing.
Although this is the case, feel free to complete our troubleshooting guide and if the issue persists raise a fault.
Thank you.
04-12-2018 1:36 AM
Mind checking again? If you could check my drops in the past two weeks. I don't believe it's dropped until now, however, has dropped a few times today...
04-12-2018 7:12 PM
While there have been a small number of drops over the past few weeks, I wouldn't necessarily be too concerned with the, however there doesn't seem to have been any drops yesterday as you advised. Did you experience these drops on both a wired and wireless connection?
04-12-2018 8:55 PM
Your picture shows disconnect(s) just a few minutes before I posted though... around 1:30am.
I'm using a wired connection to my PC, though the wi-fi is affected too as it's the router turning orange. It'll turn from blue to orange, flash orange for about 5 minutes, then come online again.
05-12-2018 3:28 AM
To add to post above, another disconnect just occured.
3:22am flashing orange
3:25am constant orange
3:26am blue & back online
I'm going to raise a fault tomorrow if you are unable to shed any light on this.
05-12-2018 7:27 PM
Apologies for that, I'd actually misread your post time as around 1:30PM thinking it was from the previous afternoon.
The drop from between 3am and 4am this morning is also showing on the account, however these can often be attributed to supplier maintenance during the night.
If you could let us know once you've reported a fault over at https://faults.plus.net, we'll be able to get that picked up and progressed with our suppliers if necessary.
Thanks.
05-12-2018 8:23 PM
Hi Harry,
I understand could be attributed to maintenance if it was a one-off, but since it isn't... I also haven't seen any on-going maintenance when checking this.
I've reported a fault via your link, the reference number is #185297672
06-12-2018 2:02 PM
Hi Afran.
Our tests aren't showing any issues still and the drops you've had don't appear to be many at all:
Could you go to your router settings at http://192.168.1.254 and confirm the firmware version from the bottom? We may need to get the firmware updated.
06-12-2018 5:02 PM
Hi Gandalf,
06-12-2018 5:05 PM - edited 07-12-2018 10:04 AM
Thanks for that, I've raised a request to our products guys to update the firmware in your router.
Let us know how your connection looks over the next few days.
[edit]
We've updated the firmware in your router.
Let us know if the drops continue.
