Huge drop in download/upload speed
- Re: Huge drop in download/upload speed
18-01-2019 1:59 PM - edited 18-01-2019 2:02 PM
I've been connected at a solid 76Mbps Down / 15Mbps Up for the past 3 years or so in my property and have never had any major problems with my line. Around 30 minutes ago my router re-synced at a much slower speed (33Mbps Down / 3Mbps Up)
I'm connected by Cat6 to my router, my router is connected to the newer 5C faceplate and the master socket is not connected to any of the other telephone sockets in my house as I never use them. (shouldn't be an internal wiring issue)
What are my line stats like on your end? Is it possible to get an engineer to look at this? I also find it a bit weird that my attenuation has increased dramatically, I didn't know that copper lines could grow that much in length in just a split second
18-01-2019 3:58 PM
Thanks for getting in touch.
I'm sorry to hear your download speeds have dropped.
We've tested your line and located an external fault on the line which will most likely be the cause of the speeds dropping.
This has been passed to our suppliers so they can investigate further and we'll update you as soon as we know more
Apologies for any inconvenience caused
18-01-2019 4:33 PM
Thank you for the reply, I'll let you know if anything changes on my end in the following days
