Hub
Hub
23-12-2015 12:06 PM
I have the new Hub one, quick question the WPS icon (below the long blue light) remains visible (orange) continually, is this normal ? Thanks.
Message 1 of 6
(1,114 Views)
5 REPLIES 5
Re: Hub
23-12-2015 12:09 PM
If you press the WPS button, top right, it should go off. Press it again and it will come back on.
Message 2 of 6
(626 Views)
Re: Hub
23-12-2015 12:30 PM
Hi tried that yesterday and just tried again, WPS flashes for about 2mins in search mode? then goes back to constant on, I asked the question because web pages are taking longer than normal to load even though my speeds are as expected.
Other things I have tried, reboot Hub 1. Connect via Ethernet cable instead of Wireless. Thanks for your input,
Message 3 of 6
(626 Views)
Re: Hub
23-12-2015 12:39 PM
in the manual there's a list of what the lights mean, mines up the loft so can't check.
Message 4 of 6
(626 Views)
Re: Hub
23-12-2015 12:47 PM
Just had a look online at the HH5 manual, seems if the Orange Wi-Fi light is on then Wi-Fi security on one or both Wi-Fi channels may be missing. You need to log on to the router and check the settings.
Message 5 of 6
(626 Views)
Re: Hub
23-12-2015 12:51 PM
Duh, sorry should have thought of that, just found my manual, " you've switched off wireless security for one or both channels" makes sense as on installation, only one device could connect at a time, after 45 mins with telephone support only solution to connect all my devices was to switch off the 5GHz band, would not work with dual band in operation. I do not require the 5GHz band so I followed his advise, to be fair apparentlyI was his first Hub 1 call. Still does not solve my flaky loading of web pages. Thanks for pointing me towards the manual.
Message 6 of 6
(626 Views)
