Engineer has been still no connection
hocumgday
The engineer has installed my fibre and has tested it and said all is good this end but I can't connect to the Internet.
He has said the problem is your end.
Please advise
hocumgday
Re: Engineer has been still no connection
Here are my router stats
Help | A-Z
home settings advanced_settings troubleshooting
Help and Advice
Helpdesk
Event Log
Information for Helpdesk agents
When contacting the Plusnet Broadband helpdesk, the agent might ask you for details about your Plusnet Hub. This page contains all of the information they are likely to request.
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ53627516
3. Firmware version: Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:03:02
6. Data rate: 9995 / 39993
7. Maximum data rate: 28523 / 78211
8. Noise margin: 18.8 / 16.9
9. Line attenuation: 15.4 / 15.6
10. Signal attenuation: 15.2 / 15.6
11. Data sent/received: 0.1 MB / 0.0 MB
12. Broadband username: setup@plusdsl.net
13. 2.4 GHz Wireless network/SSID: PLUSNET-86CR
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-86CR
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 8c:10:d4:10:1b:36
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
Fixes: 62
Try adding your username in the format username@plusdsl.net and your account password
hocumgday
Done that, still no joy. Waiting since 11am for plusnet to phone back and no joy there either. Wish i hadn't bothered upgrading 
Fixes: 65
That looks a bit odd! Looks like a 40/10 provision, didn't think PlusNet provided that option Roll eyes
jafreer
Quote from: MisterW
Shhhh Smiley
dick:green Quote fixed.
hocumgday
Do you think the engineer has plugged me in someone else's port?
