How long for SafeGuard to allow a site?
shevek
SafeGuard was blocking one of the Tumblr media servers as "tasteless" which is a bit rubbish as loads of different Tumblrs will use different media servers.
I have added the specific server to my allowed sites but it's still being blocked.
How long should it take?
13 REPLIES 13
rongtw
Fixes: 12
Re: How long for SafeGuard to allow a site?
Turn it OFF Thumbs_Up  it dont work correctly
shevek
Well, it does work for me, in that it blocks a lot of stuff I don't want my children to see!
MrSilver
Fixes: 9
When I have made changes in the past they have usually been there in a few mins, maybe up to 30 minutes.
What category is it that blocks it and what URL are you adding, i can try to see if its works here or not.
SO far ive not had many problems with it either, works for what i need it to do as an extra layer of protection!
shevek
It's still blocked this morning Angry
The category is pn_tasteless and the address is 68.media.tumblr.com
shevek
If I use the "unblock this category for an hour" it works as expected and I can see the urls.
rongtw
Fixes: 12
http://www.pcadvisor.co.uk/feature/security/how-keep-your-kids-safe-online-3411255/
http://www.techradar.com/news/software/best-free-parental-control-software-9-programs-to-keep-your-k...
Have a read here , there is a LOT better free software out there
shevek
Software is not an option for me - I don't want to have to install and manage it on all our devices across half a dozen different operating systems.
However, I had forgotten about OpenDNS's equivalent of SafeGuard... Cheers, I'll have a go at setting that up this evening.
rongtw
Fixes: 12
@shevek i dont know about the PN router , i have a Asus DSL AC68U  and Via web interface i can Time restrict and web filter , every connected device from there Thumbs_Up
Fixes: 1,484
nothing in the hub one for that
MrSilver
Fixes: 9
This is actually a really good article to read!! Nice for them to recognise education of children is a key part of it and not just a technology problem.
To me though a lot of what they say point to SafeGuard being pretty good, one of their IOS solutions is a £200 router or £5/month subscription to get a new wifi access point that can control things. Neat solution but expensive compared to free!
MrSilver
Fixes: 9
@shevek just tried the same sessings as you, already had tasteless blocked and 68.media.tumble.com gives the block page, tried unblocking couple of hours ago and still blocked. I also added a new site to be blocked and that hasnt been blocked yet either.
If I unblock for an hour then it goes straight through, weird!
shevek
Exactly! Which is why the OpenDNS option is ideal for me
shevek
Yep, exactly the same behaviour I see...
Considering the whole system seems to be a complete copy of BT's equivalent which worked fine for me ( I switched from BT to PN in August) PN seem to have broken it somehow
