Has Interleaving been removed from the line ?
- Has Interleaving been removed from the line ?
10-12-2014 1:22 PM
Hi could anyone on the DCT take a look and tell me if Interleaving has been removed from my line I have seen a drop this morning and thinking the worse ie another speed drop I was surprised to see that the profiles have increased a bit from 46Mb up to 51Mb
Is this DLM intervention has it removed the interleaving it had applied and therefore is there a chance speeds will increase further or is this due to something else ?, i know BT maintenance work is due in my area but that wasn't until the 11th according to the Plusnet email, has this been done early and would it have a negative effect when it's done if it hasn't already.
anyway it's great to finally see things go in the positive direction it may not be the 59Mb i got stuck with after the first drop or indeed the 65Mb i had originally but it's a welcome increase. thanks for any info
Message 1 of 4
(708 Views)
3 REPLIES 3
Re: Has Interleaving been removed from the line ?
10-12-2014 4:32 PM
No response am I being ignored ?
Message 2 of 4
(459 Views)
10-12-2014 4:56 PM
Message 3 of 4
(459 Views)
10-12-2014 5:36 PM
hmm thanks for that matthew, if interleaving is still on how has the profiles increased, did it go up a band or something becasue it was on low interleaving after i had my fault three weeks back.
if you say it's still on i dont know what has changed to increase the speed some what, i guess its good news for if interleaving does get removed in that i could gain a bit more back.
Message 4 of 4
(459 Views)
