congestion on ag03?
- congestion on ag03?
congestion on ag03?
congestion on ag03?
09-12-2014 9:22 PM
can see from my graph in sig last 2 nights (not checked back further) look messy, speedtest didnt look pretty, hopped from ag03 to ag01 and speedtest is fine again, I dont know yet if graph will be improved but pings look better so I think will be.
This has been affecting real use, browsing was feeling laggy which is why I checked my graph.
I am guessing there is some imbalance due to the recent outages?
Re: congestion on ag03?
10-12-2014 9:53 AM
10-12-2014 9:57 AM
Quote from: chrcoluk ag03 to ag01
Which ag03, there are 3
I'm on ptw-ag03 with no issues.
Customer and Forum Moderator.
10-12-2014 10:05 AM
10-12-2014 12:30 PM
10-12-2014 2:37 PM
Can you try reverting back to your normal username instead of the IPv6 trial username? We should try and see if that solves the problem before doing more diagnostics I think.
Thanks,
Matt
10-12-2014 5:55 PM
10-12-2014 9:29 PM
10-12-2014 11:19 PM
Today basicall I had to do a fix on my router MTU settings which dropped my PPP obviously, I then found was congested again, and have since jumped 3 times to try and get off congestion, so does look like either BTw is taking a dump or plusnet have some issues.
