GEA Test
- GEA Test
- « Previous
- 1
- 2
- Next »
Re: GEA Test
18-07-2017 11:00 AM
@lzjoker It means there may be a fault on the phone line.
Do you use it at all?
Re: GEA Test
22-07-2017 12:56 AM
That's my line been fixed. Could I get a test now to see my new speeds after line has been sorted?
Re: GEA Test
22-07-2017 3:24 PM
@DeclanTM New GEA test below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 78.3 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 362.9 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-07-20T17:00:00 |
Re: GEA Test
25-07-2017 10:55 PM
Yes occasionally the landline is used, can I get another GEA test reading please as the last one had half the info missing judging by the others posted here.
thanks
Re: GEA Test
26-07-2017 3:47 PM
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 72.2 Mbps | ||||
Upstream Speed | 18.7 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 663.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-07-13T15:45:00 |
I've also reported the phone fault. Sorry this wasn't done sooner.
Re: GEA Test
27-07-2017 4:32 PM
Can i get an updated test now that the engineer has been.
Re: GEA Test
27-07-2017 5:18 PM
Sure.
Downstream Speed | 73.7 Mbps | ||||
Upstream Speed | 18.4 Mbps | ||||
Voice Line Test Result | Pass | ||||
Time Stamp | 2017-07-14T17:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 62.6 Mbps | 77.5 Mbps | 75.0 Mbps |
Up Stream Line Rate | 18.4 Mbps | 18.6 Mbps | 18.5 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 897.7 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-07-27T15:54:53Z | 2017-07-27T16:09:53Z |
Ingress Code Violation | 1 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Re: GEA Test
27-07-2017 9:01 PM
May I ask, out of curiosity, what is meant by a "GEA test"?
About 20 minutes googling tells me "GEA" stands for "Generic ethernet access". It seems be something provided by Plusnet to their customers. Or maybe BT to Plusnet. Can anyone point me to something that specifies what GEA is? Or, even better, what a GEA test actually tests? (I'm always very suspicious of TLAs...).
Re: GEA Test
28-07-2017 1:46 AM
The test results that you've been provided with are results from a test that's been run via tool provided by our suppliers, the same test that all ISP's use (whether they use it in the same capacity as we do, is unknown).
The test (as far as I know), is software driven and reports back on details regarding your connection. I believe the information we pull back is provided by BT which pulls the information from your Local Exchange per our request to test your connection.
I wrote a guide on what those tests look like here: http://community.plus.net/library/broadband/broadband-faults-guide-our-testing/ (I wrote this a while ago but it should be still relevant).
Re: GEA Test
30-07-2017 5:49 PM - edited 30-07-2017 8:35 PM
Please can I also have a GEA test for my line?
Re: GEA Test
30-07-2017 6:41 PM
Me too as my line is in sync at 72mbit yet i'm now only getting 20mbit down... Same fault as a few weeks back so i would be interested to see what the test says thnx
Re: GEA Test
31-07-2017 3:24 PM
This thread is now locked as it would be best for those that are having issues to start a new thread with any relevant information contained within. This will also enable any test results to be placed in that thread and all information kept in one place.
- « Previous
- 1
- 2
- Next »
