GEA Test
MatthewWheeler
Fixes: 479
Re: GEA Test
@lzjoker It means there may be a fault on the phone line.
Do you use it at all?
 Matthew Wheeler
DeclanTM
Re: GEA Test
That's my line been fixed. Could I get a test now to see my new speeds after line has been sorted?
MatthewWheeler
Fixes: 479
Re: GEA Test
@DeclanTM New GEA test below
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 78.3 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 362.9
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-07-20T17:00:00
 Matthew Wheeler
lzjoker
Re: GEA Test
Yes occasionally the landline is used, can I get another GEA test reading please as the last one had half the info missing judging by the others posted here.
thanks
HarryB
Fixes: 256
Re: GEA Test
Test Outcome Pass
Sync Status In Sync
Downstream Speed 72.2 Mbps
Upstream Speed 18.7 Mbps
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Cross Talk Not Detected
Estimated Line Length In Metres 663.8
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 14
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Profile Name 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-07-13T15:45:00
I've also reported the phone fault. Sorry this wasn't done sooner.
 Harry Beesley
lzjoker
Re: GEA Test
Can i get an updated test now that the engineer has been.
Fixes: 1,600
Re: GEA Test
Sure.
Test Outcome Pass
Sync Status In Sync
Downstream Speed 73.7 Mbps
Upstream Speed 18.4 Mbps
Technology VDSL
Time Stamp 2017-07-14T17:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 62.6 Mbps 77.5 Mbps 75.0 Mbps
Up Stream Line Rate 18.4 Mbps 18.6 Mbps 18.5 Mbps
Up Time 0.0 Sec 900.0 Sec 897.7 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-07-27T15:54:53Z 2017-07-27T16:09:53Z
Ingress Code Violation 1 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
22over7
Re: GEA Test
May I ask, out of curiosity, what is meant by a "GEA test"?
About 20 minutes googling tells me "GEA" stands for "Generic ethernet access". It seems be  something provided by Plusnet to their customers. Or maybe BT to Plusnet.  Can anyone point me to something that specifies what GEA is? Or, even better, what a GEA test actually tests?  (I'm always very suspicious of TLAs...).
Pettitto
Fixes: 5
Re: GEA Test
The test results that you've been provided with are results from a test that's been run via tool provided by our suppliers, the same test that all ISP's use (whether they use it in the same capacity as we do, is unknown).
The test (as far as I know), is software driven and reports back on details regarding your connection. I believe the information we pull back is provided by BT which pulls the information from your Local Exchange per our request to test your connection.
I wrote a guide on what those tests look like here: http://community.plus.net/library/broadband/broadband-faults-guide-our-testing/ (I wrote this a while ago but it should be still relevant).
keft
Re: GEA Test
Please can I also have a GEA test for my line?
empty
Re: GEA Test
Me too as my line is in sync at 72mbit yet i'm now only getting 20mbit down... Same fault as a few weeks back so i would be interested to see what the test says thnx
Fixes: 1,483
Re: GEA Test
Moderators Note.
This thread is now locked as it would be best for those that are having issues to start a new thread with any relevant information contained within. This will also enable any test results to be placed in that thread and all information kept in one place.
