First time setup
Croger
First time setup
Hi everyone
Its my first time setup but iv come into a problem iv recieved all emails and text to say its all connected and working but when entering my username and password it doesnt connect it stays disconnected is this a fault or is it some hidden waiting time that they dont tell us about -_-
Thanks for any help
Plusnet Staff
Plusnet Staff
Re: First time setup
Hello and welcome to the Community Forums.
I have dropped you a private message asking for your username and if you could reply I'll check into your acocunt and if everything our side is set up as should be.
I've checked your account and can see it's actually a known issue on our side where the router will have the right password but something needs adding on our side to get the connection going. I've done the change which should get you online there.
Let me know how you get on.
Ben
 Ben Devine
Croger
Thanks for info and sorry for late reply currently at work so ill check when im home
When entering password it would change to another one when connecting wasnt sure if it was a security thing or a problem at least i know now ^^
Will report back tonight
Croger
so the wireless is working fine can connect to everything runs really fast very pleased
now the wired connection isnt working i carnt connet to my hub one or any website nothing is working very strange that wireless is but wired isnt
Croger
okay i unplugged the wire to modem plugged it back in now works -_-
thank you for this i have great speed and its super fast love it ^^
bigsedge
Having same problems myself. Anyone available to helpHuh
Plusnet Staff
Plusnet Staff
Hello @bigsedge and welcome to the Community Forums,
Having checked your account I can see that we are picking up the connection but the password that's been put into the router isn't the same as the one on the account.
I'll send you a private message with step by steps on with how to log into the router and change the password.
Ben
 Ben Devine
