Fibre profiling
- Re: Fibre profiling
Fibre profiling
29-04-2015 7:46 PM
Hello,
I was wondering if one of the helpful forum team could take a quick look at my fibre profile.
When my line was installed I was getting 10-12ms pings off to UK based websites and the full 40mbps my package allows. However it has deteriorated in regards to both stats; my ping is now 30-33ms and my speeds return around 30mbps.
I think I made a pretty dum mistake in turning my equipment on and off at least twice a day, so the exchange may have assumed I was having problems and dialled my profile back to compensate. I'm on an open reach modem so can't check the exact figures sadly.
I've left the equipment on now for 5 days, with no change. Happy to wait longer if needed but forums are always worth a shot
Can anyone take a look?
Thanks!
Edit : I've just read the DLM article on here. Looking at that I will just need to sit tight, until the system picks up.
Thanks!
Message 1 of 4
(779 Views)
3 REPLIES 3
Re: Fibre profiling
30-04-2015 12:47 AM
Yes don't turn off the modem, just the router if you have too.
Message 2 of 4
(360 Views)
Re: Fibre profiling
30-04-2015 6:35 PM
Hi Toast3000,
Stability is key here, so unfortunately it's going to be a case of sitting tight. The profiles should fix themselves in due course.
Matty
Matty
Message 3 of 4
(360 Views)
Re: Fibre profiling
30-04-2015 8:42 PM
I thought so, I will wait. The connection is very stable regardless, well done
Message 4 of 4
(360 Views)
