Fibre Hub1 Router dropping every night !
buono
Re: Fibre Hub1 Router dropping every night !
Hi @EmilyD
Just a quick update, no change this week. Still poor speed in the evening, this will be very disappointing if I can expect no change until 23/11.
adamwalker
Fixes: 221
Hi Buono, I've just checked with our supplier and the VLAN move is still pending. I
 Adam Walker
buono
@adamwalker , just an update. Less than 3Mb/s tonight.
MasterOfReality
Fixes: 57
hi @buono
Our supplier has been made aware that your VLAN migration has not completed.
They've sent the report over to the Complex Fault team to review and asked us to check back in 24 hrs.
Please accept my apologies, and thank you for the patience and understanding you have shown whilst we have been working on this issue.
Thanks,
MoR
buono
Thanks for the update @MasterOfReality. I have had an answerphone message from you guys which I appreciate. They said that the move off the hot VLAN might be possible. I guess they might have done that for me now as the evening speeds are improving.
On the attached graph the previous difference between day / evening speeds is obvious.
Will keep an eye on things until the end of November when the exchange has had the upgrade work done.
Thanks.
buono
For completeness and to conclude this thread. The faults team confirmed I was on a hot VLAN, and I have now been moved. Things are now back to normal with low latency and speeds consistently at close to 40mb/s
Thanks.
deank
Fixes: 14
Glad to hear that it's all resolved for you now. Please let us know if you have any further queries.
rjwharfe
deleted
