FTTC plus homeplugs = 1/2 speed?
gyre
Folks, I've tried to debug this problem until I'm well and truly blue in the face.  I really need your help Smiley
I'm on Plusnet Unlimited Fibre 80/20.  My Plusnet profile says I can get over 70mbit/sec.
I plug my supplied BT Openreach VDSL modem into my Draytek 2920 router.  I can connect via PPPoE fine.  Smiley
If I plug in a laptop via ethernet into one of the LAN ports on the 2920 and do a speedtest, I get 71mbit/s plus.  Fine.  Smiley
However, if I then plug in a homeplug via the same LAN port downstairs, and move the same laptop upstairs and plug it in to another homeplug, I get only 31mbit/sec.  Consistently.
I've tried a pair of devolo 200avs.  I expected those to be somewhat limited.  I then tried a pair of solwise 500avs.
So clearly the homeplugs are somehow limiting my bandwidth, right?
Well, yes, but I don't know why.  Using the 500av homeplugs I'm able to get a sustained rate copying files from PCs downstairs to PC upstairs of over 10MB/sec in both directions.
Why would the homeplugs allow 80+mbit/sec on file copies, but only 31mbit/s on Internet access?  MTU problems?  (I'm using 1492 on my PPPoE connection)
Completely stumped here and open to any advice.
Thanks!
-- gyre --
23 REPLIES 23
Pettitto
Fixes: 5
Re: FTTC plus homeplugs = 1/2 speed?
Hi gyre,
I can't believe I've come across this thread. I moved this weekend just gone and get pretty much full 80/20 but get around 30Mb on 200 Home Plugs. I've just ordered a pair of TP Link 500's to see if this improves throughput.
Ethernet Cable straight into the router gives 74Mb - I can only think that's an issue with the quality of the Home Plugs or something plugged in next to the Home Plugs that's causing interference. What speeds do you get through the 500's?
Oldjim
Resting Legend
Fixes: 63
A suggestion
Try the homeplugs on the same fused circuit
It shouldn't make any difference BUT it is worth a check
Jaggies
I have a pair of TP-Link 200 Home Plugs, and get about half my download speed on that connection. A points to consider:
Are either of the Home Plugs plugged in to an extension socket strip?
This is touted as a mighty no-no, but although the received wisdom is that you'll be very lucky if they work at all set up like that, especially if you have a surge protector, I have both of mine plugged in to that type of socket - they obviously work, but I reckon that's probably the cause of the slower speed.
MauriceC
Resting Legend
Fixes: 17
It may be worth reading this page
Solwise is a significant supplier of this type of equipment and in this article tries to be realistic about the performance you should expect.
N.B.  It may be worth looking at their Twisted Pair product?  I've not tried this yet - but it is a contender for an extension to "The Shed".
HTH
Maurice
picbits
Something else to try is to remove *all* devices from all the plug sockets in the house then use only the modem/router/homeplugs and see what happens.
There could be RF filter devices in just about anything you plug into your mains which could interfere with the operation of the homeplugs.
If your speed increases significantly, then plug things in one by one and see what happens.
gyre
Thanks folks.  All good and sensible advice.
The 2 solwise 500av homeplugs are on the same fused circuit.
I get over 80mbit/sec when transferring files between the plugs.  That's a sustained 10-11MB/second either direction copying files.
There are no other homeplugs anywhere else in the house.  Just the one downstairs and the one upstairs.
They each have their own socket.  No trailing leads etc.
As they both have filtered mains passthroughs (piggys), I'll try plugging the router and modem directly into them and see if that helps.  Will report back if it does.
Thanks!
gyre
OK, after looking at wireshark output I think I've found the problem.
I was setting a MTU on the draytek 2920 of 1492.  Changing it to 1442 gave me back the missing bandwidth.
Sigh.
-- gyre --
gyre
Well, sort of.  Sometimes I get 60-ish mbit/sec, and sometimes 40.  Still better than what I was getting before the MTU change, but not perfect.  Suprised changing MTU from 1492 to 1442 made any difference at all, but changing MTU values on the router makes a huge difference.
anniesboy
Chris.
Following your saying you were buying 500 Homeplugs, Im wondering how they perform ?
I use 200 Homeplugs at the moment but FTTC is hopefully coming soon to my cabinet hence my interest.
beeceegee
Fixes: 4
A lot depends on the quality of your household wiring, but the Solwise article referred to above explains very well why you should not be too optimistic regarding the throughput using homeplugs. I had a set of Devolo 500AVs and was disappointed with the results (for the price). I swapped them for a much cheaper set of Solwise 200AVs; frankly the 25-30Mbps throughput I get using the 200s is hardly any worse than the 500s. As the plugs are only used for streaming the TV and related kit it's plenty
gyre
I've been using devolo 200s for a few years.  100% rock solid.  A few months back I got a few devolo 500s.  After a week I sent them back.  They would drop packets and then go off-line for minutes on end.  They were just awful.
The solwise 500s I'm using are very solid.  In terms of reliability I'm happy with them so far.  In terms of speed, I'm not seeing a lot of difference between them and the old 200s as far as my broadband is concerned.  Mind you, the supplied app says I'm connecting between 170 and 210 mbit/s.  I'll have to try to optimise that by using the filtered pass-thru ability of the solwise piggies when I next reboot my home network and see if that helps.
-- gyre --
tijara33
Fixes: 6
I'm running a pair of 500s & getting 45 down & 13 up, almost  exactly the same as when wired.
deathtrap
Homeplugs and xDSL don't mix well, but hardly surprising really, the amount of EMI or RFI they must generate, that will most likely be the cause of the lack of performance on the internet connection, If they are having an adverse impact on the VDSL2 signal @ your modem ( causing high error rates) then don't be surprised when DLM strikes and lowers your speed and increases latency,
Pettitto
Fixes: 5
The fact that Homeplugs and VDSL use the same frequency doesn't help either 😕
