FTTC - Vodafone Suresignal IP Problems?
- Re: FTTC - Vodafone Suresignal IP Problems?
17-12-2014 2:10 AM
In the last few days I have had problems with my Vodafone Sure Signal box. I have carried out the troubleshooting of that and it's not the box, it appears my problem is that my net connection is not reaching the Vodafone servers IP address at 212.183.133.177.
I have pinged it, and it times out, also I have carried out a tracert with the following results;
C:\Users\PhilDesktop>tracert 212.183.133.177
Tracing route to cluster4.vap.vodafone.co.uk [212.183.133.177]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms router.asus.com [192.168.1.1]
2 17 ms 16 ms 24 ms lo0.10.central10.pcl-bng03.plus.net [195.166.130
.164]
3 18 ms 31 ms 18 ms irb.10.PCL-CR01.plus.net [84.93.249.81]
4 40 ms 31 ms 29 ms ae1.ptw-cr01.plus.net [195.166.129.0]
5 29 ms 39 ms 39 ms lndgw2.arcor-ip.net [195.66.224.124]
6 52 ms 55 ms 37 ms 85.205.0.86
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
It appears to be a problem with plusnet'srouting of my traffic not allowing me access to that destination IP address.
The problem has only started this month, and reading the Vodafone support forums, it appears that there are many Plusnet users experiencing the same suresignal woes trying to reach Vodafone's servers.
Please help!
17-12-2014 5:48 AM
IPSec VPN stopped working overnight
17-12-2014 1:10 PM
I was using IP Sec over UDP VPN successfully for quite some time to connect to work. It stopped working yesterday (it stops somewhere in the middle of negotiation, one of ISAKMP packets gets changed/dropped).
VPN service is working fine for my colleagues that use a different provider, not working for the ones that are on Plusnet. I tried connecting from the same PC using my 3 mobile data and that worked.
I have contacted Plusnet support and was told that nothing was changed on their side...
I snooped through forums and checked the firewall on plusnet side, was off (tried low as well because there is a comment that VPN definitely works with that) - rebooted the router after.
I also tried telnet to the router and removed binding for IKE and ESP, saved and rebooted.
Didn't help.
I really think this is something on Plusnet side because it is happening to several people and started at the same time... Please help.
Thank you!
Re: IPSec VPN stopped working overnight
17-12-2014 1:33 PM
As the sure signal uses a VPN to Vodafone I guess it could be related.
17-12-2014 1:52 PM
There no issues that we're aware of with VPN's at the moment.
With regards to the suresignal boxes we suspect that those affected are on one of the new IP ranges starting with 146.200 or 146.99.
If anybody is having issues with their suresignal boxes can you either log into your router and disconnect then reconnect your connection or reboot your router to see if this resolves your issue.
17-12-2014 2:16 PM
17-12-2014 2:16 PM
Can you PM me with the following info so I can ask someone to have a look.
When did the VPN last work?
What port(s) is the VPN using?
Is the VPN between 2 Plusnet connections? or a Plusnet connection and an different ISP?
Who is the originator of the tunnel setup request?
17-12-2014 2:41 PM
Quote suresignal boxes we suspect that those affected are on one of the new IP ranges starting with 146.200 or 146.99.
My sure signal stopped working overnight 212.159.xxx.xxx, and my VPN is not able to accept connections
I have.
1) Reconnected my ppp sesion
2) Set the plusnet firerwall (from off) to low
3 Reconnected the ppp sesion
4) Set the plusnet firewall to off
5) Reconnected the ppp sesion.
6) Rebooted the sure signal and tried to connect to my vpn from the three mobile network.
No luck
Ian
edit: also some trouble on FTTC?? http://community.plus.net/forum/index.php/topic,135002.0.html
and vodafone forums....all plusnet http://forum.vodafone.co.uk/t5/Vodafone-Sure-Signal/Sure-Signal-v1/td-p/2326717 and many more on that forum (mostly plusnet customers)|
17-12-2014 2:44 PM
Ian
Vodafone suresignal
17-12-2014 2:46 PM
anyone with a suresignal having problems today? I have 2 devices and they both stopped working this morning
over on the Vodafone forum some people are saying that it is localised to plusnet users.
Anything changed at the plusnet end?
lewer
17-12-2014 2:49 PM
the VPN was working on Monday (and a lot of months before that) and stopped working from Tuesday.
Ports in wireshark are 500 and 4500 (ipsec nat-t), I can attach wireshark if you like? I also have the wireshark of the good connection (using 3 network) which uses the same ports...
This all fails in configuration stage (authentication passed) as if nat-t packets have been tampered with (detailed logs on the client report that packet was received for the invalid session).
The VPN server is on the other provider, I am the VPN client. I didn't manage to find colleagues who have Bt account, I believe they are in front of plusnet, so can't say whether the issue came from plusnet or bt openreach... If I find out, I will inform you about that.
Thank you,
Maggie.
17-12-2014 2:51 PM
17-12-2014 2:52 PM
Re: Vodafone suresignal
17-12-2014 3:08 PM
http://community.plus.net/forum/index.php/topic,135019.0.html
and here:
Suggest that this thread and the one above are locked in favour of the first one?
17-12-2014 3:48 PM
I was asked by Plusnet Livechat to add a post here.
